Against "interpretation" - Comments
343 replies · 39K views
Pleonasm said:
I know of a working physicist who is of the opinion that the pilot wave model is a theory, not just an interpretation.
Is he claiming that the pilot wave model makes different predictions from standard QM?
If he is, you should ask him to back up that claim (since AFAIK every other physicist agrees that the pilot wave model makes the same predictions as standard QM).
If he is not, then he's just using the words "theory" and "interpretation" differently from how we define them here at PF. That's a matter of choice of words, not physics.
Pleonasm said:
How one defines "theory" as opposed to "interpretation" is ultimately a philosophical question
Nonsense. It is a semantic question as are all definitions. Philosophy does not own all definitions. Scientific definitions belong to the scientific community just as financial definitions belong to the financial community.
Pleonasm said:
My point was that your initial statements are contradictions. You wrote "definitely not" to my claim, only to follow it up with a "generally not" example. This is a contradiction.
I said “generally considered” not “generally not”. Please don’t misquote me.
There is no contradiction. A definition is what a word is “generally considered” to mean by the community using the word. “Generally considered” indicates my belief that the terminology I am using is not my personal usage but is the usage by the general scientific community.
PeterDonis said:
Because the pilot wave version of standard non-relativistic QM has an explicitly nonlocal interaction between the pilot wave and the particles.
More precisely nonlocal interaction between the particles, in the same sense in which Newtonian gravity is a nonlocal interaction between particles, not a nonlocal interaction between the gravitational field and particles.
PeterDonis said:
This feature is a key reason why nobody has yet been able to come up with a consistent relativistic version.
In the paper linked in my signature below I argue that Bohmian mechanics predicts that the Standard Model is only an effective theory emergent from a more fundamental non-relativistic theory. In this way Bohmian mechanics becomes a "theory" (in the sense of making a new prediction) and the problem of relativistic Bohmian mechanics is avoided.
But to me it doesn't seem to be the same as in the Newtonian case. There, if I move a particle here, it will result in a measurable effect to the particle over there. In the Bohmian case there is nothing you can do to a particle here that will have observational consequence to a particle over there, right?
You seem to be speaking as if, in the Newton case, a particle can move by a human will. But this is wrong. In Newtonian mechanics particles move by deterministic forces, not by human will. So one has to use a passive language: If a particle moves here, it will result to a measurable effect over there. When put in this form, the same can be said about Bohmian mechanics.
I move one of the particles, you can see that I've done something by measurering the other particle. Just like Alice can choose and measure spin in a direction (or whatever she wants), but here Bob cannot tell just looking at the other particle.
You don't seem to understand my objection. I insist on formulation that does not contain athropomorphic notions such as the bolded ones above.
Why? Science is done by anthropomorphic entities such as Bob and Alice who do have wants. Seems counterproductive to insist otherwise.
That objection doesn't appear anywhere in Newtonian mechanics, why is it so essential in Bohmian mechanics?
Consider two different scenarios for one of the particles. Say it is stationary, or it moves back and forth. The two scenarios have different effect on the other particle. They (the two scenarios) are distinguishable. And that distinction is local for the other particle. In the Bohmian mechanics that is not the case. Same as standard quantum mechanics. Locally the behavior of one particle doesn't distinguish the two different behaviors of the second particle.
Newtonian mechanics is deterministic, so you can't just arbitrarily choose to move one of the particles. Whatever any particle does is completely determined by the initial conditions of the universe; the same goes for what you do. I think that is the point that @Demystifier is trying to make.
But @martinbn is making a point different from @Demystifier, namely that in the conventional analysis of long-distance correlation experiments, one has to assume that Alice can make choices. Otherwise everything was determined according to @Demystifier at the big bang, and nothing at all needs to be explained, nothing baffling is left.
To be convincing with his argument, Demystifier has to explain is why the Bohmian universe behaves such that seeming choices can be made by Alice!
[In the original post I had also claimed: ''In a Bohmian universe, one can also consider two universes that are identical except for a difference in the initial conditions of some particle at a particular time. One finds that this difference in initial conditions does not influence the other particles.'' But this is not true; see the next two posts.]
A. Neumaier said:
In a Bohmian universe, one can also consider two universes that are identical except for a difference in the initial conditions of some particle at a particular time. One finds that this difference in initial conditions does not influence the other particles - all beables of the two universes (except for the position of the one particle moved) behave exactly the same!
Maybe I'm misunderstanding something. In one formulation of Bohmian mechanics, the wave function gives rise to a "quantum potential" whose value depends on the locations of every particle in the universe. So changing the location of one particle potentially affects every other particle.
Oh, yes, you are right, sorry. The wave function is unaffected by the particles, but the motion of the other particles depends on its value at the particle whose position changed, thus the latter affects the former.
This answers the concern by @martinbn in a more direct way than the response by @Demystifier had suggested.
Yes, this does answer my concern better. But I still have a question left. My point was that in Newtonian gravity I can by only observing one particle deduce something about the behavior of the other, without the need of me knowing the initial state of the universe, just local observations of one particle. That is not possible in quantum mechanics. Is it possible in Bohmian mechanics? If not, then the claim that the nonlicality of Bohmian mechanics is the same as that in Newton's gravity is simply incorrect. This was the only point that I wanted to make. If on the other hand it is possible, then it seems that Bohmian mechanics is substantially different from QM, not just an interpretation. So different that it is already ruled out.
I'm not sure I understand what distinction you are making. Bohmian mechanics is deterministic, just as Newtonian mechanics is. Each particle affects every other particle, just as with Newtonian mechanics.
That is, in principle, different from standard QM, which is nondeterministic, but in practice they make the same predictions. If you don't know the exact positions of every particle, but only a probability distribution, then Bohmian mechanics only allows you to make probabilistic predictions.
You can say nothing exact without knowing the state of the universe at the particular moment, since the dynamics of each particle depends on all others. This is as in Bohmian mechanics.
That's true for a large part of science (applied science, mainly), but not for all science. (For instance, in cosmology one does not ask what happens if Alice creates a new galaxy or Bob creates a new quantum fluctuation as a seed for a new inflationary Universe.) The point of Bohmian mechanics is to interpret quantum mechanics in a manner that does not involve observers. So if one wants to understand Bohmian mechanics, then referring to Alice and Bob is, well, counterproductive.
Well, that's a problem for any physical theory that claims to be fundamentally deterministic or fundamentally probabilistic. If so, then where does the human free will come from? The most physical answer is that free will is an illusion. Things just happen due to the laws of physics, but our brain then somehow interprets some of those as being "chosen by oneself". How exactly that happens in the brain is something that physics alone cannot answer.
It is not possible in Bohmian mechanics, but to understand where does the difference come from you have to ask the following question: How exactly one observes a particle in Newtonian gravity? The point is that one observes it by a local non-gravitational interaction. Typically, one observes the stars and planets by watching them, which involves interaction with light. For instance when you watch the Moon, the light interacts with the Moon (by reflecting from it) only when the light touches the Moon. It is this locality of interaction that allows one to determine the position of the Moon. In Bohmian mechanics, on the other hand, particles do not interact via any local interactions at all (see my "Bohmian mechanics for instrumentalists"). In this sense, there is no analogue of "light" in Bohmian mechanics. Bohmian particles are analogous to dark matter in astrophysics, which, as you might know, cannot be directly observed precisely because it does not interact with light.
Or to make the long story short, nonlocality in Newtonian gravity is very much like nonlocality in Bohmian mechanics, but the difference is that, in Newtonian gravity, there is something additional which is local and non-gravitational.
I am not so sure about this. I can sit at the seashore and watch the tides. If the moon disappears I will realize that by the tides. I don't need to look at the moon. Newtonian gravity allows instantaneous signal transmission, QM doesn't. Does BM? I guess not, so it is not the same as Newtonian gravity.
I think BM does allow instantaneous effects in the same sense that Newtonian gravity does. But it can't be used for communication unless you know the exact locations of every particle in the universe. Which you don't.
Let me illustrate with a very simplified version of EPR. Suppose that Alice is trying to transmit a single bit (0 or 1) to Bob. Alice has a device with two buttons labeled 0 and 1. Bob has a corresponding device with two LEDs, one labeled 0 and one labeled 1. Let's suppose that there is a bit-valued hidden variable ##\lambda## that is either 0 or 1, and that ##\lambda## depends in some sensitive way on the exact positions of every particle in the universe.
Let ##A## be Alice's choice, 0 or 1. Let ##B## be Bob's result, 0 or 1. Then the laws of the universe work so that:
##B = A + \lambda(1 - 2A)##
So if ##\lambda = 0##, then ##B = A##. If ##\lambda = 1##, then ##B= 1-A##.
I think it's clear that Alice can't dependably send a 0 to Bob unless she knows the value of ##\lambda##. However, her choice does affect Bob's result, in the sense that if she makes the opposite choice, he will get the opposite value.
How would you make the Moon disappear? Which force would you apply for that? Gravitational force or some other force? If it is some other force, then, as I already pointed out, the difference emerges from the fact that in Newtonian gravity there are some additional forces.
Demystifier. Why does Bohmian Mechanics belong to "b) No" in the "Find Your Own Quantum Interpretation" chart for the question "Is the world completely described by the state in the Hilbert space? The "a) Yes" is for Many Worlds for example. You may argue the beabble in BM is only for the particles like tables or chairs. But what would be wrong by stating the wave function in BM is also real like in Many worlds? What theoretical conflict can occur?
The answer is "no" because the world is described by the state in Hilbert space AND the instantaneous positions of every particle. The state alone is not a complete description.
Why, in many worlds, there are no instantaneous positions of every particle since the world is conpletely described by the state in Hilbert space?
I'm not sure how to answer a "why" question like that. It just doesn't. In the simplest case of one particle, you have a wave function ##\psi(x,t)##. The particle has a probability of being here or there, but the wave function doesn't tell you where the particle is.
I know. But why did you state that "the world is described by the state in Hilbert space AND the instantaneous positions of every particle"? Is this only for Bohmian Mechanics?
Yes, in Bohmian mechanics, the world is described by the wave function and the positions of every particle. In Many-Worlds, the world is described by just the wave function.
Ok. That's clear enough.
About many worlds. I'd like to know something. In a cat. How often are there quantum choices in the atoms and molecules of the cats enough to create different mixed states or worlds? And if the quantum choices affect the organs and endocrine system. So the cats can be in different moods in different worlds?
