AGMA pitting resistance factor of safety (SH)
  • Context: Engineering
  • Thread starter Thread starter ironfalls18
    Engineering design Gears
The AGMA pitting resistance factor of safety (SH) is a critical parameter in gear design, specifically referenced in Shigley's Engineering Design. If SH is determined to be 2, it indicates that the transmitted load can be increased by a factor of 4 while maintaining performance. This relationship is derived from the AGMA pitting equation, where the safety factor and transmitted load are related through squaring. Therefore, the statement regarding the safety factor and load increase is true.
  • Understanding of AGMA pitting resistance concepts
  • Familiarity with Shigley's Engineering Design principles
  • Knowledge of gear load transmission mechanics
  • Basic algebra for manipulating equations
  • Review the AGMA pitting resistance equations in detail
  • Study the relationship between safety factors and load in mechanical design
  • Explore advanced gear design principles in Shigley's Engineering Design
  • Learn about contact stress calculations in gear systems
Mechanical engineers, gear designers, and students studying mechanical design principles will benefit from this discussion, particularly those focused on gear performance and safety factors.
ironfalls18
If the AGMA pitting resistance factor of safety (SH) for a certain gear was found to be equal to 2, it means that the transmitted load can be increased 4 times, while still get the required performance.
None.
is the statement true or false?
This is from Shigley's Engineering design, I'm unable to approach this in the right way,
I need help in "catching the string".
Welcome to PF. :smile:
You need to show your Attempt at the Solution before we can provide tutorial help. That's in the schoolwork rules (see INFO at the top of the page).
Is the statement true or false?
Find the AGMA pitting equation, look for the safety factor and the transmitted load. Are they separated in the equation by a square or a square root? 2 = √4 ; 2² = 4 ;
AGMA Contact Stress and Pitting Resistance
  • · Replies 26 ·
23K
