Air brake over hydraulic brakes
31 replies · 15K views
NascentOxygen said:
Something like the clatter of a machine-gun? Is that brought on simply by the driver lifting his foot off the accelerator?
It's a bit more complex, but not brain-busting. I'm sure that anyone who drives a standard or an auto with a manual valve body knows that downshifting is a very good way to decelerate or to hold a reasonable speed on a hill. It's referred to as "engine braking" or "compression braking". The Jake takes that a bit farther. If a cylinder doesn't fire, the compression stroke is wasted (as in if a spark plug malfunctions). It actually acts as a "spring" against the rotation of the engine. In normal circumstances, there would be a rebound effect that would see a bit of energy regained by the piston rebounding off of that compressed charge in the combustion chamber. A Jake disables the fuel injectors for specific cylinders, and then opens the exhaust valves to eliminate that rebound.
Danger's description of Jake brakes is the best yet in this thread. In a gasoline car, if you lift your foot off the gas, the engine will provide a regarding force to slow the car down. If you down shift to make the engine spin faster the braking force is greater.
A diesel provides almost no such regarding force at all because it does not have a throttle.
The Jake brake gives the diesel engine this same engine braking ability, but to a higher degree. Different systems work differently, but they all convert the engine onto an air compressor and discharge thru an orifice to convert energy to heat and noise.
