Aircraft guidance question: Effect of mounting sensors at the CG vs on the Tail
  • Context: Undergrad
  • Thread starter Thread starter cessna1525
    Moment Rocket Sensor
The discussion revolves around the effects of mounting sensors, specifically a magnetometer, at the center of gravity (CG) versus the tail of a rocket or airborne vehicle. Participants explore the implications of sensor placement on stability, data accuracy, and moment behaviors, with a focus on inertial navigation and the dynamics of airborne magnetometer systems.
  • Some participants inquire about the benefits of placing a magnetometer at the CG compared to the tail, suggesting that mounting at the CG may reduce amplified moments due to the distance from the CG.
  • Others argue that the tail is where data is needed for balancing, steering, and stabilizing the rocket, implying that sensor placement should consider operational requirements.
  • A participant mentions that the orientation of the magnetometer will vary similarly regardless of its position on the vehicle, but the distance from the tow vehicle and ground will change based on the sensor's location.
  • There are discussions about maintaining the sensor's horizontal orientation when supported only at the CG, raising questions about stability and balance.
  • Concerns are raised about the necessity of constant corrections for sensor placement, considering factors like yaw and the center of lateral pressure, which may affect overall stability.
  • Technical details about the integration of various sensors (GPS, accelerometers, gyros) and their roles in determining orientation and position are mentioned, along with references to mathematical concepts like quaternions and Kalman filters.
Participants express differing views on the advantages and disadvantages of sensor placement at the CG versus the tail, indicating that multiple competing perspectives remain without a clear consensus.
Participants highlight the complexities involved in sensor placement, including the movement of the CG as fuel is consumed and the dynamic nature of the vehicle's orientation and stability. There are unresolved considerations regarding the impact of various forces and corrections needed for accurate data collection.
cessna1525
Hi,
Can I someone please explain to me, the moment behaviors of having something fixed on CG vs on Tail in a rocket? are there any benefits of having a Sensor on CG than fixed on the tail?
Thank you
Welcome to PF.
Is the something, a linear accelerometer and rotational gyroscope, used for inertial navigation?
The CG will move as fuel is consumed. How will you move the something?
The tail will be where the data is needed to balance, steer, and stabilise the rocket.
Hi,
Thank you very much for the quick reply, actually. the case here is about an airborne Magnetometer bird, just wanted to know if there is any benefit of having the Mag sensor on CG instead of on the Tail section, The argument I heard from my colleague is Having on the CG is better because having it on the Tail section will cause amplified moments due to the arm, does this make sense? , I thought it doesnt matter like that
Like this?
https://www.bgr.bund.de/EN/Themen/G...omagnetometrie/aeromagnetometrie_node_en.html
Yes, exactly, only difference is we are hanging it on one point, just above the CG,
How do you keep the sensor body horizontal if you only support it at the CG?
It is balanced on the CG , and CG is Infront of the Center of pressure, and it stabilized as it speeds up, usually 15 m/s forward speed.
The orientation of the magnetometer will vary in the same way, independent of its position on the bird.
However, the distance of the magnetometer from the tow vehicle, and from the ground, will vary with the changing orientation of the bird, but will be minimised if the instrument is close to the centre of mass of the bird.
Thank you so much for the input, is there any subject material on this which I could Study more?
what is the theory behind
When you stir a cup of tea, at every point in time, there is at least one point that is fixed in position. Likewise, when a magnetometer bird moves through the air, the centre of mass is probably near a virtual "fixed point" on the bird.
https://en.wikipedia.org/wiki/Brouwer_fixed-point_theorem
You have GPS, 3D accelerometers, 3D rate gyros, and a 3D magnetometer. Everything is fixed to the frame of the bird, but offset in different positions.
The orientation of the bird comes from the 3D rate gyros.
The long term track is determined by GPS. The short term track comes from the 3D accelerometers, corrected for orientation. The long and short term tracks are combined in a Kalman filter.
https://en.wikipedia.org/wiki/Kalman_filter
The position of the magnetometer is computed from the spatial track.
The orientation of the magnetic field is corrected for bird orientation.
The orientation of the bird is computed with quaternions to avoid gimbal-lock in the calculations.
https://en.wikipedia.org/wiki/Quaternion
https://en.wikipedia.org/wiki/Gimbal_lock
Transducers.
https://www.analog.com/en/technical...l-ways-to-assemble-mems-inertial-sensors.html
Choosing the place to put it could give a least worst susceptibility to error but would it not be necessary to apply corrections all the time?
In addition, won't yaw and the vertical axis of the centre of lateral pressure also be relevant? Centres of pressure will probably move about, in any case, as the device is pulled in different directions. I'd imagine that damping and stability would also be relevant - more than just choosing the placing wrt the centre of pressure.
  • · Replies 21 ·
  • · Replies 16 ·
  • · Replies 35 ·
