Airflow and hair dryer efficiency
The discussion revolves around the efficiency of domestic hair dryers, specifically exploring the relationship between heat energy, airflow, and drying effectiveness. Participants are examining the complexities involved in modeling the drying process, which includes various interrelated factors such as temperature, humidity, and airflow dynamics.
  • Participants are attempting to relate multiple variables affecting drying efficiency, including heat energy supply and airflow. Questions are raised about the feasibility of creating an accurate mathematical model given the complexity of the interactions between these variables.
The conversation is ongoing, with some participants expressing skepticism about the existence of a precise model. Others suggest breaking down the problem into fundamental principles and exploring the underlying mechanisms of hair dryer operation. There is a recognition of the challenges involved in developing a comprehensive understanding of the drying process.
Participants reference external sources and regulations, such as the EU's proposed limits on hair dryer energy consumption, indicating a context of academic investigation for a degree dissertation. The discussion highlights the need for a detailed exploration of the physical principles at play.
Darren#68
Poster has been reminded to posts their work in the first post of schoolwork threads.
Can the power efficiency of the domestic hair dryer be improved by reducing the heat energy and increasing airflow?
Probably not. Think about drag force and see what you come up with.
Thanks for your reply. I've actually been trying to find something that relates heat energy supply, evaporation rate, partial pressure, relative humidity, water(liquid), water(vapour in air), temperature, surface area of hair to be dried and airflow! With nearly all these variables both in constant flux and affected by each other it's starting to appear an impossible job to get an accurate mathematical model of the process.
So far the most useful sources have been the Illinois Physics Dept forum (see link), and Modern Drying Technology Vol 4, Energy Savings (Ian. C. Kemp) 2012 ch1.
https://van.physics.illinois.edu/qa/listing.php?id=1440
The EU (European Union) is looking to put a limit on drying rate to power consumption of hair dryers of 5.2 Wh/g/min (ref: The EU Ecodesign Directive/125/EC Draft Task Report (2014, p.126). I'm investigating where energy use can be improved for my final degree dissertation, hence the question regarding increasing the air flow rate to dry hair.
I doubt an accurate model exists, in all honesty. You're probably going to have to break it down to its fundamental principles, and formulate your model that way. So you plug it in, do coils heat up? What's the relationship between the current (or voltage, if you prefer) and the temperature of the coils? Well, that'll depend on the size, number of turns, etc...
I actually don't know how a hair dryer works, it might not be coils.
So now you have heat, and you need to pump it out, the faster you pump it out, the greater the drag force, (v^2 most likely) the greater the energy loss via heating between the hot air and your environment, as well as the air molecules coliding with each other and not even getting to the hair. So how does the angle of incidence change with velocity?
If you want a working model, it will be a long process, not that it should discourage you in any way, however. How does a hair dryer work, and what is your motive to produce this model?
Hehehe, I think we could get really stupid with this if we wanted to... How would you describe the water density within the hair? How hot are the molecules of air? How many molecules will it take to evaporate 1 molecule (might be better to deal with mols) of water?
When do you consider the hair dry?
20K
