Airplane Vector Problem: Drawing the diagram
10 replies · 3K views
susan_khan
Thread moved from the technical math forums to the schoolwork forum
An airplane has an air velocity of 500 km/h [N 30 E] and encounters a wind from [S 75 W] at 180 km/h, find the ground velocity. Make sure you draw a big, labelled diagram.
Please help! I’m understand the calculations that need to be done (cosine law then sine law for the angle) but I’m a little confused on how to draw the diagram. Could someone please help if you can ?
Do you understand the terms "air velocity" and "ground velocity"? If so, please explain them in your own words.
For the drawing, make the vertical (y) axis North, and the horizontal (x) axis East. Basically it looks like a compass with N, E, S, and W labeled for the 4 axis vectors out from the origin.
Then draw a vector from the origin out in the NE direction of the appropriate length to represent the airplane's velocity with respect to the air. Then draw a vector from the origin out in the SW direction with the appropriate length to represent the wind. Then copy that wind vector with its tail on the nose of the airplane's air velocity vector, preserving the angle and length of the wind vector. You have just drawn the vector sum of the airplane's velocity and the wind velocity, which represents the overall velocity of the airplane over the ground.
Does that make sense?
Yes thank you so much!!
Reply
You're welcome. I left some steps out there at the end, so you still have some work to do, but at least you now can start the diagram. You still need to think about the questions @kuruman has asked, since they go toward your intuition for how to solve problems like this. :smile:
I’m getting an angle of 45 degrees is that correct?
I’m getting an angle of 45 degrees is that somewhat correct?
I dunno. Can you upload your diagram and post your calculations? To upload a PDF or JPEG file, use the "Attach files" link under the Edit window.
To post math, you can start off just typing it into the edit window since you are new here, but as you get more experience, please use LaTeX to post math here. There is a "LaTeX Guide" link also under the Edit window. :smile:
It's insufficient. Your answer should be in the form V km/hr [X angle Y], i.e. specify the speed and the bearing.
Sorry I meant I’m getting an angle of 45 when I draw my diagram not the actual angle that needs to be solved for using sine. When I add 15 and 30 based on my diagram I get 45. Is that the right angle to plug into the cosine law?
Please show your diagram and label all vectors in it. Then explain how you plan to use the law of cosines using that diagram.
Reply
