Alculate the x-component of the electric field
The discussion focuses on calculating the x-component and y-component of the electric field produced by a uniformly distributed positive charge Q along the positive y-axis, with a negative point charge -q located on the positive x-axis. The correct formula for the x-component is established as Ex = Q/(4πε0x√(x²+a²)), while the y-component requires a definite integral over the range y=0 to y=a. Participants emphasize the importance of deriving the components through integration rather than relying solely on formulas from textbooks.
  • Understanding of electric fields and charge distributions
  • Familiarity with calculus, specifically definite integrals
  • Knowledge of Coulomb's Law and its applications
  • Proficiency in vector components and their calculations
  • Study the derivation of electric field components using integration techniques
  • Learn about the application of Coulomb's Law in continuous charge distributions
  • Explore the concept of vector fields in electrostatics
  • Review the mathematical treatment of electric fields in two-dimensional systems
Students studying electromagnetism, physics educators, and anyone involved in solving problems related to electric fields and charge distributions.
ybad
Positive charge Q is distributed uniformly along the positive y-axis between y=0 and y=a . A negative point charge −q lies on the positive x-axis, a distance x from the origin
Calculate the x-component of the electric field produced by the charge distribution Q at points on the positive x-axis.
Calculate the y-component of the electric field produced by the charge distribution Q at points on the positive x-axis.
E = q/4πε0r2
r2 = x2+y2
So I was able to get the first part of the question relatively easily by using some techniques from the textbook, which resulted in the correct answer:
dEx = Q/4πε0x√(x2+a2)
But when I try to find the y-component, I get the answer:
dEy = (Q/(8πε0a))*(1-(x/(√x2+a2)))
This answer results in the following message from the website:
"Your answer either contains an incorrect numerical multiplier or is missing one."
I need help finding the problem since I don't know where I may have gone wrong.
Just making sure; do you mean, "on the positive y-axis"?
This gave you the correct answer? The units are incorrect. It might be simply a typo (because it's almost correct) but I want to make sure you understand how to do this before finding the y-component.
Edit:
The units are correct sorry... I misread the equation
Assuming it is intended as Ex = Q/(4πε0x√(x2+a2)), the dimensions are correct (but yes, the expression is wrong... it should not tend to infinity as x tends to zero).
You don't say how you got that answer. We can't tell you where you went wrong if you don't post your working/logic.
E = q/4πε0r2
r2 = x2+y2
As pointed out in post #2, this answer is incorrect. Did you do a typo somewhere? And why "dEx"? It's just Ex.
You should be figuring the problem out for yourself rather than looking for formulas in a textbook.
If you did that you would have come up with one definite integral over y=0 to y=a for the x component, and a different definite integral, also over y=0 to y=a, for the y component.
BTW why is q mentioned in the problem?
Also, both the x and y components of the E field are obviously negative for all x. The answers have to be sign-reversed in x for x < 0.
Most likely for a later part of the question.
