Algebra with Complex Numbers & Imaginary Unit
  • Context: Undergrad
  • Thread starter Thread starter aaaa202
    Imaginary Unit
The discussion revolves around the algebraic properties and definitions of complex numbers, particularly the imaginary unit i. Participants explore the implications of defining i as the square root of -1 versus defining complex numbers as ordered pairs of real numbers. The conversation includes theoretical considerations, examples, and historical context regarding the development of complex numbers.
  • Historical
  • Some participants question how it makes sense to do algebra with complex numbers when i is defined by an equation with two solutions.
  • Others argue that the definition of i as either i or -i is merely notational, as both satisfy the same algebraic properties.
  • One participant expresses confusion about the equivalence of i and -i, seeking examples to clarify this relationship.
  • Another participant emphasizes that complex numbers can be defined as pairs of real numbers, which allows for consistent algebraic operations without relying solely on the definition of i.
  • Concerns are raised about the pitfalls of defining i as √(-1), particularly regarding the application of square root rules that only hold for positive values.
  • Some participants discuss the historical origins of imaginary and complex numbers, with differing views on whether they stem from quadratic equations or higher-order polynomials.
  • A later reply challenges the assertion that complex numbers originated from quadratics, citing historical examples involving cubic equations.
  • There is a discussion about the pedagogical approach to introducing complex numbers, with some advocating for a focus on quadratics while others suggest higher-order polynomials are also relevant.
Participants express a mix of agreement and disagreement regarding the definitions and properties of complex numbers. While some find common ground on the notational aspects of i and -i, others contest the historical context and pedagogical methods for introducing complex numbers. The discussion remains unresolved on several points, particularly concerning the implications of different definitions of i.
Participants highlight limitations in understanding the implications of defining i as √(-1) versus (0, 1), as well as the potential for confusion when applying algebraic rules. The discussion also reflects varying interpretations of historical developments in the field of complex numbers.
aaaa202
When i is defined by an equation which has 2 solutions, how does it make sense to do algebra with complex numbers?
How is i defined by an equation which has 2 solutions?
Oh, I understand what you mean. I don't think it matters, because of the definition, everything true for i will be true for -i too. It becomes purely a notational issue, we have two solutions, and they are additive inverses, just pick a symbol for one and put a "-" in front of the other to show that it is the additive inverse. It doesn't matter.
I feel kind of stupid, but I don't understand this argument that if everything is true for i it will be for -i too. Could you give some examples? I feel it's kind of the same as choosing a right or lefthanded coordinate system but then again I have not understood that either.
It doesn't! We don't define "i" by "[itex]i^2= -1[/itex]"- although elementary treatments may introduce it that way.
Rather, we define the complex numbers as pairs of real numbers, (a, b), with addition defined by (a, b)+ (c, d)= (a+ c, b+ d) and multiplication defined by (a, b)(c, d)= (ac- bd, ad+ bc). That way (a, 0)+ (c, 0)= (a+ c, 0) and (a, 0)(c, 0)= (ac, 0) sp we can associate the "complex number" (a, 0) with the real number, a. Also, if we define i= (0, 1) then we have [itex]i^2= (0, 1)(0, 1)= (0(0)- 1(1), 0(1)+ 1(0))= (-1, 0)[/itex] so that "[itex]i^2= -1[/itex]". We can then say (a, b)= (a, 0)+ (0, b)= a(1, 0)+ b(0, 1)= a(1)+ b(i)= a+ bi.
The point is that the way a mathematical concept is introduced to the student is not necessarily the way it is formally defined by mathematicians.
Okay so maybe you can help me understand where it goes wrong in the following (which motivated this thread for a start):
1. 1/i = sqrt(1)/sqrt(-1)
2. 1/i * i/i = sqrt(1/-1)
3. i / -1 = sqrt(-1)
4. -i = i
What is the problem by simply defining i=sqrt(-1) and where does it go wrong in the above when doing so?
4. -i = i
The problem is going from line 1 to 2,
[tex]\frac{\sqrt{a}}{\sqrt{b}}=\sqrt{\frac{a}{b}}[/tex]
Is a rule that applies only to positive a and b values.
OK, I think it will become obvious to you.
3i + i = 4i
3(-i) + (-i) = 4(-i)
For example, or even
e^(-i(pi)) = -1
Where i/-i is only referenced once.
If we make the 'basis' for the 1 dimensional vector space -i instead of i, the change is only superficial.
Essentially, I believe that -i and i may be regarded as equals (not that they are equal to one another, but that they are on the same footing.)
It doesn't matter which one is which, as long as both exist. I don't believe you can say ANYTHING that differentiates I from -i... but I may be wrong.
I see. But what exactly is the difference then between defining i=(0,1) and i=√(-1). Is the only problem that the last one could make you mistakingly think that you can apply usual rules for square roots? And noting that this is not the case, are the 2 definitions the equivalent?
All you've done is arbitrary chosen (0,1) to be i instead of (0, -1). If (0,1) = i, then (0,-1) = -i, and then we're back where we started: -what's the difference?-
i'm in agreement, Hall, with 1Mile. originally the concept of "imaginary" numbers and then "complex" numbers did come from, i believe, the solution to quadratics (or higher-order polynomials) set to 0 when there were no "real" numbers (the set of rational and irrational numbers that are ordered on the "real" number line) that satisfy those equations.
saying that
[tex](a, b) + (c, d) = (a+c, b+d)[/tex]
makes sense just from a normed, linear space POV. but when you say that
[tex](a, b) \times (c, d) = (ac-bd, ad+bc)[/tex]
as a definition, we can just as well say that is motivated by or a result of the definition:
[tex]i^2 = -1[/tex] .
i might recommend the OP to take a look at the wikipedia article on it, especially the 2nd section. i think that explains it pretty well without just requiring the OP to accept [itex](a, b) \times (c, d) = (ac-bd, ad+bc)[/itex] as a definition for how complex numbers multiply.
This is not true. It comes from the the Tartagalia-Cardano formula, i.e. the cubic formula. As you know cubics always have a real solution, however from time to time the formula generates solutions with square roots of negative numbers. For example ##x^3 - 15x = 4## produces
##x = \sqrt[3]{2 + \sqrt{-121}} + \sqrt[3]{2 - \sqrt{-121}}##
but this equals 4.
Another example is in 1702, when Leibniz demonstrated to Hyugens that
##\sqrt6 = \sqrt{1+\sqrt{-3}}+\sqrt{1-\sqrt{-3}}##
who exclaimed "defies all human understanding".
All of this predates the notion of complex numbers.
there's a reason i parenthetically inserted "or higher-order polynomials".
but, from a pedagogical POV, i don't understand why it's necessary to go above quadratics to introduce someone conceptually to imaginary and complex numbers. you don't need to go to cubic or quartic to see the need for imaginary and complex numbers.
You wrote "set to 0 when there were no "real" numbers (the set of rational and irrational numbers that are ordered on the "real" number line) that satisfy those equations." That part is wrong. It's the real solutions that caused the discovery. Back then ##x^2 + 1 = 0## simply had no solutions.
But you weren't making a point of pedagogy. You were making a claim about the history of mathematics.
no. you cannot represent me nor what i was saying. you cannot even presume to.
it was purely a point of pedagogy from the beginning. as best as i can tell, you were making an historical point. but i was covering my arse anyway.
What? You wrote
originally the concept of "imaginary" numbers and then "complex" numbers did come from...
Explain please how that is not about history. You explicitly used the phrase "originally...did come from". How am I supposed to parse that as a pedagogical point?
Look, if you are claiming that teaching complex numbers is easier through quadratics, then I agree with you. But that was not what you wrote in the first paragraph.
Folks is this arguing helping?
Yeah. I'm done. Moving on.
About 1Mile's point about i and -i being equals.
As Halls pointed out complex numbers are formally defined as pairs, with ##i = (0,1)##. This space of numbers is of course ##\mathbb{C}##.
Let's create a new number system. I'll define ##j = (0,-1)## and call this space ##\mathbb{D}## which is composed of numbers ##\alpha + \beta j##.
What 1Mile is saying that if I make a statement (theorem) that is true on ##\mathbb{C}##, there is an equivalent statement that is true on ##\mathbb{D}##. And we can use conjugation to write it down.
they are qualitatively equivalent (both have equal claim to squaring to -1), but not quantitatively, since they are not zero and are negatives of each other.
[itex]\mathbb{C}[/itex] is not [itex]\mathbb{R}^2[/itex]. Halls was complete when he stated the rules of addition and multiplication of these pairs. my point is that the "formally defined as pairs" is not the original meaning (in case you're wondering, i mean the original pedagogical meaning), but can be made equivalent as long as you define the rules of addition (trivial, about the only way you can) and multiplication (less trivial, there are other ways to define multiplication of 2-vectors which are not compatible with complex numbers). i really don't see any point to it or advantage over the common pedagogy (geez, i have to be careful to remind snafu, lest the words be misconstrued).
Getting all argumentative is getting us nowhere, rbj. I think all of pwsnafu's replies have been very accurate.
you have every right to think that.
(i'm here for information. [itex]\mathbb{C}[/itex] is not the same as [itex]\mathbb{R}^2[/itex]. call it argumentative or not, but if anyone "simplifies" the concept of complex numbers to reducing the concept to only "pairs" of real numbers, they need to read that quote from Einstein: "Things should be as simple as possible, but no simpler.")
The set of complex numbers is not reals squared. True.
And no one has said this.
The statement is ordered pairs of real parts.
Yet by leaving out i it can confuse some, and is easier for others. The questions is "is it equivalent with the definitions for operation defined? I have no doubt of this, yet...
Yet the statement
does define the rules of the complex system, not the number i.
i of course is undefined in the reals, yet is a constant such as the real part of "a+bi" or bi is such that a defines how many "i"s are added together.
Of course this can confuse folks very easy, and part of the whys "i" were and are avoided by a lot.
but the sets are one-to-one with each other. (what did they call that? "entire"? can't remember.)
well, don't know if i agree with that. i quoted someone making, without the reference to "[itex]\mathbb{R}^2[/itex]", an equivalent statement.
complex numbers are more than just ordered pairs of real parts. [itex]\mathbb{R}^2[/itex] are also ordered pairs of real parts. while there is a simple and complete one-to-one mapping of [itex]\mathbb{R}^2[/itex] to and from [itex]\mathbb{C}[/itex], it is tempting for some to think that they are the same, but [itex]\mathbb{C}[/itex] requires an operation or rule that [itex]\mathbb{R}^2[/itex] does not. and it makes it different.
and that is solely what my disagreement with Halls is about. it's about pedagogy, and i see little advantage, conceptually, to the pedagogy that leaves out [itex]i^2=-1[/itex].
First to have the ordered pairs, takes two sets of reals; not just one: with the rules as stated in this thread. The intersection of coarse is at (0,0) with one set vertical to the other.
End result is that "i" is equivalent to (0,1)
Which is why I referred to the link I posted.
The problem with boards and such talks is that to state all involved is not practical. Just to get into a talk about a term or terms can lead a topic way off.
And I learned the old way myself. I have always had a bit of trouble when they say (a+bi) that b is a real.
I have had to adapt to all of this myself.
bijection? There are several obvious bijections between the two entities, as long as they are viewed as simple sets.
isomorphism? If you tack on the appropriate addition and multiplication operations, there are two obvious isomorphisms between the two enties when viewed as fields.
automorphism? There is one non-trivial automorphism between [itex]\mathbb{C}[/itex] and itself. The mapping is complex conjugation (invert the imaginary part).
Back to the original question.
Well how does it make sense to use the reals when the square root of 1 has two answers?
(-1) squared= ?, and (1) squared equals what?
Yet both -1 and 1 are two separate numbers.
Oh and the thinking -i is the same as i is also a mistake.
Yes squared they become the same answer, yet -i times i= 1, not -1.
It's a good practice to say isomorphism and automorphism between which specific structures? Fields? Groups? Rings? Topological spaces?
As fields, there are uncountably many automorphisms of ##\mathbb{C}##, but only ##2## continuous ones.
yah, it's pretty much bijection. for some reason, i don't remember that term for what i would commonly call "one-to-one" or "invertible". i just wanted to include the property in the mapping that in either [itex]\mathbb{C}[/itex] or [itex]\mathbb{R}^2[/itex], there were no orphaned points. "entire" appears to mean something like analytical at every value in [itex]\mathbb{C}[/itex]. it's been 35 years, and there's a lot i don't remember.
but regarding the OP's original question, i think the most direct answer is that, while there are two different values of [itex]i[/itex] that have equal claim to satisfying [itex]i^{\ 2} = -1[/itex], it doesn't matter which value you pick as the "positive" [itex]i[/itex]. if every lit and textbook were changed and [itex]-i[/itex] and [itex]+i[/itex] were swapped in the language, every theorem would continue to be just as valid. it's sort of like the (mathematical) equivalence to twist; either clockwise or counter-clockwise can be defined as "positive twist" as a convention. or swap left-hand rule with right-hand rule (say, for the cross product) everywhere.
they are qualitatively different. only one of those two numbers are the multiplicative identity.
it is no mistake to think of [itex]-i[/itex] and [itex]i[/itex] as qualitatively the same. every property [itex]-i[/itex] has, [itex]+i[/itex] also has.
so, lost, would you have trouble with the meaning of [itex]a+bi[/itex] for [itex]b[/itex] a real and positive integer? i don't know why you would have to adapt very much for that.
  • · Replies 0 ·
