Algebraic/Matrix Manipulation (linear algebra)
4 replies · 2K views
boings
I have attached the relevant question as an image (for sake of ease)
Also attached, in blue.
Thanks a lot for any help at all!
You could consider ##B^k Y = 0##. Which property does B need to get non-trivial solutions for Y? How is that related to a?
##Y=(B-I_2)X##. How do you get Y=0 (which is a solution to the equation above) with non-trivial X? How is that related to a?
Perhaps the very beginning is where I'm having trouble, I don't know what times a matrix would be equal to zero. Is it the transpose? Or perhaps a matrix whose determinant is zero?
If you have studied matrices at all then you should know this basic property: the equation Ax= y has a unique solution if and only if A is invertible: [itex]x= A^{-1}y[/itex]. And that is only true if A has non-zero determinant.
The equation Ax= 0 always has the "trivial" solution, x= 0. It has other solutions if and only if its determinant is 0.
You're right, I should know that basic property :) I've been cramming too much this semester so I tend to forget.
Thanks a lot it makes good sense.
