Algerbraic logarithm method question
  • Thread starter Thread starter Cosmicon
    Logarithm Method
The discussion revolves around a set of equations involving variables x and y, specifically focusing on the equations y^(x-3y) = x^2 and x^(x-3y) = y^8. The original poster attempts to isolate the variable y to simplify the equations but encounters difficulties due to the presence of y in the exponents. They express a desire to find a non-logarithmic method to solve the problem.
  • Exploratory, Problem interpretation, Assumption checking
  • Some participants question the omission of logarithmic methods, suggesting that the original poster may not have fully considered this approach. Others explore the possibility of modifying the powers in the equations as an alternative to logarithms. There is also a mention of a similar problem involving different equations, where the original poster notes challenges in simplification.
Participants are actively discussing various methods to approach the problem, including the potential use of logarithms and alternative techniques. There is recognition of the usefulness of certain methods, and some participants share insights on how to manipulate the equations. However, there is no explicit consensus on a single approach, and multiple interpretations are being explored.
The original poster has specified a constraint that x-3y is not equal to -4, which may influence the approaches discussed. Additionally, there is a consideration of the validity of negative solutions in the context of the equations being analyzed.
Cosmicon
First of all, greetings to the scientific community here at Physics Forums.
The following set of equations is given:
y^(x-3y) = x^2
x^(x-3y) = y^8
With the next assumption given: x-3y is unequal to (-4).
My attempt was to isolate the y variable in both of the equations so that i will be able to divide the the equations and receive a simple x^a = b equations. This did not help, because the powers of the x's included the y, with no option to get rid of it.
I Would like your assistance with finding the shortest, most efficient, non-logarithmic way to solve this question, asap.
Why haven't you taken the logarithm of the equations? Isn't that the method you said you were asking about in the title?
You are right it is a possibility. I did not fully mention my request here in the topic.
I am searching for an additional method to logarithm, by modifying the powers in the two equations.
Just tackled with another question with great similarity:
x^(2x+y) = y^4
y^(2x+y) = x^16
I noticed the identity of the powers in the left sides of the equations, but even after immediatly deviding the two equations, I get stuck.
What would be the most efficient way to solve this with no log?
It is the method of logarithm, you just don't write log ...
x^{(2x+y)^2} = y^{4(2x+y)} = x^{16\cdot 4} = x^{64}. Therefore (2x+y)^2 = 64 (that's where we really did logarithms without mentioning the word), so assuming x>0, y>0 we have 2x+y=8. Then x^8 = y^4 so x^2=y. Substitute in the equation: 2x+x^2=8 then solve the quadratic equation. The only positive solution is x=2 so then y=4.
I assumed x and y are positive so that irrational exponents would be defined. But to solve for integer solutions, you could allow negative x,y since integer powers still make sense.
edgar, using which formula did you make this calculation:
<br /> x^{(2x+y)^2} = y^{4(2x+y)} = x^{16\cdot 4} = x^{64}<br />
Start with x^{(2x+y)} = y^{4}, raise both sides to power 2x+y , get x^{(2x+y)^2} = y^{4(2x+y)}.
Start with y^{(2x+y)} = x^{16}, raise both sides to the power 4 , get y^{4(2x+y)} = x^{16\cdot 4} .
OK?
OK?
yes, I now understand this technique. very useful and widespread in problems involving equations.
*According to this, when solving the quadratic equation, two answers apply: x=2, and x=-4.
why is x=-4 (y=16) not valid in this case?
** It is also important to mention that another solution in this form of questions:
when the two bases are equal to 1, the powers can be placed with any suggested number.
Therefore: when x=1, y=1.
