Alternating Outputs with 555 Timing Chips
  • Thread starter Thread starter gboff21
1 reply · 4K views
gboff21
Using an array of 555 timing chips I want to turn one output on for 3 minutes then turn it off, then turn another output on for three minutes then turn it off. I understand how to alternate each output but it is having no outputs after 6 minutes that is the problem.
It would seem that two 555's, operated in monostable mode, would do the trick. The first is triggered and its output goes high. This output is tapped, and also drives a second, so when the output goes low it trips the second and its output goes high. When the 2nd times out the cycle is done. Check this website:
http://www.dummies.com/how-to/content/electronics-components-double-up-with-the-556-dual.html
Here is a short video of the circuit operating as you wish:
The key is the small cap between the output of the first 555 (or first half of 556) and the trigger input of the second.
Also, it looks like a 1 meg resistor and 100 uF cap in the timing circuit should give you 180 seconds. You probably already knew that. Hope that helps!
