Alternative energy sources? How about photons?
The discussion revolves around the concept of using photons as a direct energy source, particularly in the context of science fiction writing. Participants explore the plausibility and effectiveness of a hypothetical device called a "Photonic Black Box" that would store photons for later use, contrasting it with more conventional energy sources like fusion reactors and solar panels.
  • One participant proposes the idea of a "Photonic Black Box" to store photons, questioning its plausibility and effectiveness compared to other energy sources.
  • Another participant challenges the feasibility of storing photons, suggesting that it implies zero emissivity, which may render the concept impossible.
  • Some participants express skepticism about the practicality of using trapped photons to generate energy, emphasizing the need for a clear mechanism of how this energy could be harnessed.
  • A participant mentions existing research from MIT on storing solar energy thermally and re-radiating it at shifted wavelengths, suggesting it may offer insights into energy storage and efficiency.
  • Concerns are raised about the low kinetic energy of photons and the inefficiency of converting photon energy into useful forms for powering devices.
  • There are references to science fiction concepts, such as "slow glass," which relate to the idea of storing light, indicating a blend of speculative ideas with scientific principles.
Participants express a range of views, with some questioning the feasibility of the proposed idea while others explore its implications. There is no consensus on the practicality of using photons as an energy source, and the discussion remains unresolved.
Participants highlight limitations in understanding the mechanics of photon energy storage and conversion, as well as the speculative nature of the proposed concepts. The discussion reflects a blend of scientific inquiry and creative exploration.
Willy Pete
I'm looking to get into the realm of science fiction writing and am currently working out how the main "SciFi energy source" works in this world I'm trying to make. Fusion reactors are the obvious go-to, but I wanted to get creative, that said: how plausible/effective would it be to directly harness photons as an energy source? Less as using sunlight with a solar panel and more trapping photons and using them to generate energy to power different devices.
The current idea is something called a Photonic Black Box, in which one can store photons. My only concern is that this could be either incredibly stupid or otherwise realistically ineffective compared to other hypothesized energy sources.
Implies emissivity equals zero, therefore, impossible?
This reminds me of "Why do we need nuclear energy? We can just use electricity!"
So in layman's terms (aka terms I understand) the answer is this is stupid and I should stick to fusion or something else?
I'm not that dumb ;D
As an aside:
May not be what you were looking for, but MIT has apparently done some neat stuff with storing solar thermally, then re-radiating at shifted wavelengths to better match the desired spectrum. This potentially offers both storage and increased efficiency.
https://www.technologyreview.com/s/603497/10-breakthrough-technologies-2017-hot-solar-cells/​
But you're dismissing that comment without thinking it through. Remember, YOU said this:
You never described how a box of photons can actually be used!
In solar panels, one uses the HEAT energy from photons to heat water tubes. In solar cells, one converts the photon energy directly into free electrons inside the photodiode and creates electricity. You never explicitly described HOW to use these photons that you are trapping. How do you intend to harness their energy into useful form?
So actually, what you have said is analogous to Vanadium's quote, even if you don't realize it.
Zz.
SunThief said:
As an aside:
Interesting all the same! Thanks.
That's why I came here, I don't know enough about photons to explain this without throwing the science out of science fiction. I don't know if it would even be possible to use a photon as an energy source (and I reasonably had my doubts), so I figured you folks would know more.
But something I do know is that in a fission reactor you're turning water into steam to drive a turbine and this turbine spinning is what generates the electricity, hence the above comment of "Not being that dumb." I'm dumb about the hypothetical use of photons as the 'electron of the future', sure I'll give you that. But I'm not so dumb as whoever said the quoted comment about nuclear energy vs electricity.
If you don't know what you're writing about, shouldn't you write about something else?
In a fission reactor, you are turning energy that is given out during a nuclear fission, and converting it to heat, which in turn, turned water into steam to create a mechanical form of energy. This mechanical form can be used directly (steam engine), or converted into electricity (electrical turbines). Electricity generated is then used to power devices.
There is a clear chain of "events" here.
EM radiations have been used to convert its energy to heat. Solar water heater does that. EM radiations have also been used to convert to electrical energy directly via solar cells. But somehow, these are not the form of "energy" that you are looking for.
The problem here is that a "photon" doesn't carry that much kinetic energy in the first place, and the conversion factor sucks, for it to turn into useful form to power mechanical devices that either do work directly, or converting it to electrical energy without the use of solar cells. In the world of photonics, we use light to carry information or signal, not do work.
Zz.
I'll try to be more charitable in my interpretation than some of the others (not saying I disagree with them...):
Photons are just "particles" of light. If you could store them in a box [with perfect mirrors], you'd have to take them out and consume them in order to to use them; e.g., store light from the sun in a box and then open it later to throw the light at solar panels, to generate electricity.
It seems like a pretty weird way to store energy to me. But maybe you're ok with that* and can build a story around how a perfect one-way mirror is used to collect sunlight and store it "fresh".
*Pretty much every piece of far science fiction technology contains an element of nonsense. That's what makes it science fiction...or rather why some people break off a separate category from more plausible near-term/realistic SciFi and call it "Science Fantasy", in which you would put Star Trek/Star Wars. Trouble is, a lot of people don't realize they are not plausible.
I know it is a tangent to the OP, but the idea of storing photons for later use reminded me of Bob Shaw's "slow glass."
https://en.wikipedia.org/wiki/Light_of_Other_Days
I still remember reading that story, must have been almost 50 years ago.
Presumably as the photons bounce around inside the box of ideal mirrors they exert a force on the walls? Perhaps all you need to turn it into a rocket is to make a small hole in one side?
If this is all one wants, then why fuss around with a box of photons when one can just stick a laser on the spacecraft ’s rear end?
Zz.
On sci-fi basis it would be qualified as a kind of battery. But what would be the source?
Zz.
Agreed. Not sure if that would satisfy the OP request to use photons as an energy source?
Willy Pete said:
... trapping photons and using them...
Here is a company making devices for residential use.
correct me if I'm wrong, but photons are energy carriers, not energy source. So the OP's idea of using photons as energy source is not possible.
That is also true for batteries and petroleum. With petroleum you could one step further and say that petroleum is not a energy carrier unless there is an oxidizer too.
My impression was that he was talking about Sun produced energy from nuclear fusion. Photons are emitted by the surface of the Sun. Photons are "trapped" and then used as needed. Here is a https://www.nasa.gov/ames-partnerships/technology/technology-opportunity-optical-fiber-for-solar-cells on solar fiber optics.
If you can build a perfect mirror then you can store photons and use them whenever you want. You could bottle magnified sunlight if the entire inside of the bottle was a perfect mirror.
Do you know where I can buy this perfect mirror? I need 17 of them.
Zz.
In the 23rd century there is no money; just have the replicator make them for you.
Zz.
I get them at the Ideal Hardware Store. They're in the aisle past the massless springs. If you see the monopoles you've gone too far.
Whenever I shop there I always slip on the frictionless surfaces.
  • Poll Poll
  • · Replies 22 ·
  • · Replies 21 ·
