Am I Measuring the Current and Voltage Correctly in this Circuit?
6 replies · 2K views
ft92
Wire up a circuit with C3 in parallel with C1 and C2 in series. You will need to measure the current arriving at the capacitors (before they are fully charged) and the voltage across capacitor C2.
I'm not sure if I'm measuring the current before the capacitors are fully charged. Can anyone help me?
thanks
What are the component values? No resistors in the circuit? The capacitors will be charged instantly then.Are you sure you are asked to find the current and not the charge?
no, there are no resistor. that are all the instructions I have.
Then I think you are asked to find the charge arriving on each capacitor. This is a dc circuit containing capacitors. Since there is no resistance involved, all the capacitors will be charged instantly,hence the current will cease instantly. You can find the charge in terms of C1, C2, C3 and voltage V.
Is this in preparation for an actual experiment using wires, etc., or is this for a computer simulation, or is it some sort of thought exercise?
The typical meter is very limited in what it can reveal about a fast-changing current or voltage, other means may be needed.
Is the page of text to the left of your sketch circuit related to the question? Perhaps you could post that?
Does your current meter have a "peak hold" feature?
thank you everybody but my draw was correct eventually :) It was just an online exercise where I had to drag and drop the capacitors and voltmeter in the right place.
