Can Temperature Alone Affect the Volume of Air in a Room?
  • Thread starter Thread starter Serhiy
    Air
The discussion centers on the relationship between temperature and the volume of air in a room, specifically using the ideal gas law, PV=NRT. Participants emphasize that the formula applies only when temperature (T) is expressed in Kelvin, as it must be an absolute temperature. The conversation also highlights the importance of understanding how changes in the number of moles (N) and volume (V) relate to temperature adjustments. Key points include the necessity of maintaining constants for pressure (P) and the gas constant (R) while varying temperature.
  • Understanding of the ideal gas law (PV=NRT)
  • Knowledge of absolute temperature scales, specifically Kelvin
  • Familiarity with concepts of pressure, volume, and moles in gas behavior
  • Basic algebra for manipulating equations
  • Research the implications of using different temperature scales in gas laws
  • Explore the relationship between pressure, volume, and temperature in real-world applications
  • Study the concept of absolute zero and its significance in thermodynamics
  • Learn about the behavior of gases under varying conditions using simulations or experiments
Students studying physics or chemistry, educators teaching gas laws, and anyone interested in thermodynamics and the behavior of gases under varying conditions.
Serhiy
The air pressure in the room is 10 ^ 5 pascals, the temperature is 20 degrees Celsius. To what temperature should the air be heated so that 5% of the molecules leave the room?
p=nkT
maybe the temperature need to be changed from Celsius to Kelvin
Well, yes, that formula applies to absolute temperature. Can you make an attempt to solve this yourself?
Is this a well defined question? How does the air escape the room?
Through a pressure valve, of course!
  • Haha
I think the gist is what temperature is required to expand the volume by 1.05. it should be straight forward, but really terrible question.
Anyway, I'd use the ideal gas law, pv=Nrt. Only temperature and volume change. I don't think temperature units much matter.
  • Skeptical
maybe your thoughts are correct, but this task looks in the same record that I described to you, but in my native language. but thank u
PV=NRT applies ONLY with T in Kelvin.
ok, thank you
yup, i try again. thank u
Lord Kelvin would be turning in his grave!
But why does it matter. If v scales by 1.05, so would t. I have to think about that for a minute,but I think it is linear.
Technically the scale itself doesn't matter as long as you adjust the relevant constant(s), but the scale must start from ##0##.
Okay, I thought about it 😉
No. It only applies when T is an absolute temperature. Whether Kelvin or some other absolute temperature scale is used is irrelevant.
No, this is incorrect. (Although pretty close ...)
Orodruin said:
No. It only applies when T is an absolute temperature. Whether Kelvin or some other absolute temperature scale is used is irrelevant.No, this is incorrect. (Although pretty close ...)
I would appreciate some clarification on that note, the second part..
Oh, do you mean 1/.95 vs 1.05?
Keep in mind that these are the homework forums. The problem should not be solved by others before the OP has gotten it right.
The problem tells you to fix ##V## and reduce ##N## to ##0.95N##. Why would you want to redefine the problem as a change in volume? And, if you do, you better check you have the correct change in volume.
Does it? I see how that is different from what I was thinking, but the question is a bit ambiguous. But I get what you are saying. It is t percent of the "molecules".
I apologize if I was being too direct.
Oh shoot, it's late for me right now, or early if you like. I was thinking v and n were proportional, so it shouldn't matter.
It does matter.
Yes, ##V## and ##n## are proportional -- if all other things (##P##, ##R## and ##T##) are held constant. But ##T## is not being held constant. We are varying it.
In this case it is ##V##, ##P## and ##R## that are constants. Can you see why?
This means that the relevant relationship is between ##n## and ##T##.
jbriggs444 said:
It does matter.
Yeah, it was late and I probably shouldn't have been answering homework topics. I got the answer roundabout, but I see that perok suggestion of a pressure valve, even in perhaps jest, is the right way to think about it.
  • · Replies 16 ·
  • · Replies 31 ·
  • · Replies 18 ·
