Amount of charge flowing through a resistor?
7 replies · 23K views · last reply
druuuuuuuunnk
the current through a resistor is 3 mA. What charge will flow through it in 200 seconds?
if the resistor has a resistance of 2.0 kΩ what will be the power dissipated in it?
for the first one, i have no idea. i can't seem to find any formula that is relavent to this so I am guess the answer is simple but I am missing a vital piece of information that would link the dots.
for the second one i was thinking the power disippated in the resistor would be the same as the resistance, becuase the resistance is stopping anything above 2.0 V to enter the resistor?
any help is appriated, this is for my exam tomorrow.
What's the definition of current?
No, power is not the same as resistance. But the power dissipated depends on the current and the resistance. (Look it up!)
"Electrical current is a measure of the amount of electrical charge transferred per unit time. It represents the flow of electrons through a conductive material.
Current is a scalar quantity (though in circuit analysis, the direction of current is relevant). The SI unit of electrical current is the ampere, defined as 1 coulomb/second"
so its 600 coulombs
im still confused about power, I've tried looking it up but it doesn't make any sense, is it the same as voltage?
so V=IxR
meaning 3 mA x 2 kΩ giving me 6 Volts that are being dissapated in the resistor
Current = Charge/Time, thus Charge = Current * Time.
so its 600 coulombs
Redo that calculation.
No. Read: http://hyperphysics.phy-astr.gsu.edu/hbase/electric/elepow.html#c2"
Ok so, to find the charge in 200 seconds. I multiply 3mA by 200 because charge = current*time
Giving me 600A ??
And for the second part I use Power = voltage * current
So the power dissipated in the resistor = 600 (current) * 2 (resistance) is this wrong ?
Actually for the second part, I'm meant to use power = current squared * resistance. So I'd get 720,000
Giving me 600A ??
Careful: mA means milli-Amps = 10-3 Amps
(And the charge would be in Coulombs, not Amps.)
Same issue with your power calculation.
