The problem involves determining the magnetic field around a cylindrical conductor with a current density that varies radially. The current density is defined as J(r) = J0e−r/R, and the task is to express the magnetic field in regions both inside and outside the conductor, using Ampere's Law.
- Exploratory, Mathematical reasoning, Assumption checking
- Participants discuss the relationship between current and current density, with some attempting to derive the total current from the current density using integration. Questions arise about the definition of current density and the appropriate differential area for integration.
The discussion is ongoing, with various participants providing different approaches to integrating the current density. Some have pointed out potential errors in calculations and the need to clarify the limits of integration. There is no explicit consensus on the correct approach or solution yet.
Participants are working under the constraints of homework rules, which may limit the information they can share or the methods they can use. The varying nature of the current density is a key point of discussion, affecting how participants approach the integration.
