Amplitude of harmonic oscillator
The discussion focuses on deriving the amplitude of a driven simple harmonic oscillator with a sinusoidal driving force. The steady state solution is expressed as a combination of sine and cosine functions, specifically in the form: (sin(wt)*(1-w^2)-cos(wt)*w)/f(w). The amplitude of the steady state solution is confirmed to be 1/sqrt(f(w)), where f(w) is defined as (\omega^2-\omega_0^2)^2+(\lambda\omega)^2. The user successfully utilized Maple to verify their calculations and simplify the expression.
  • Understanding of simple harmonic motion and oscillatory systems
  • Familiarity with sinusoidal functions and their properties
  • Basic knowledge of differential equations
  • Experience with Maple for mathematical computations
  • Study the "Driven Harmonic Oscillator" section in the provided document for deeper insights
  • Learn how to derive amplitudes in oscillatory systems using trigonometric identities
  • Explore advanced features of Maple for simplifying complex expressions
  • Research the implications of damping factors in harmonic oscillators
Students studying physics, particularly those focusing on oscillatory motion, and anyone interested in mathematical modeling of dynamic systems.
longrob
I have a simple harmonic oscillator system with the driving force a sinusoidal term. The question is to find the general solution and the amplitude of the steady state solution
I found the steady state part of the solution. It is of the form:
I'm told that the amplitude of the system in steady state should be 1/sqrt(f(w)) but I can't derive it. Can anyone help ?
Thanks
use trig identity and reduce the equation to sin(A-B), amplitude is the factor by which the stated term is raised
But the coefficients of each sinusoidal term are different...
is your steady state solution correct? it gets crazy if i reduce it to some trig identity
and what is f(w) equal to?
Yes I'm sure it's correct. This is homework so I'm loathed to post the whole details. However, take a look here:
http://nuweb.neu.edu/dheiman/U600/DHO.pdf
Look at the section "Driven Harmonic Oscillator" on page 4. The solution given is exactly what I want (with lambda, w_0 and F_0/m all equal to 1). I just can't derive it from my own solution. By hand I just used a trial solution of p.cos(wt) + q.sin(wt) and equated coefficients, which lead to the form I posted above. I also used Maple to check this, and it agrees.
The (1-w^2) factor isn't under a square root?
no, it's not...
Another look at this in Maple:
[Sorry, fiddling with latex...]
In Maple:
{\it s2s}\, := \,{\frac { \left( -{\omega_{{0}}}^{2}+{\omega}^{2} \right) \sin \left( \omega\,t \right) +\cos \left( \omega\,t \right) \omega\,\lambda}{{\omega}^{4}+ \left( {\lambda}^{2}-2\,{\omega_{{0}}}^{2} \right) {\omega}^{2}\\<br /> \mbox{}+{\omega_{{0}}}^{4}}}\]}
which simplifies to:
{\frac {\cos \left( \omega\,t-\arctan \left( -{\omega_{{0}}}^{2}+{\omega}^{2},\omega\,\lambda \right) \right) }{ \sqrt{{\lambda}^{2}{\omega}^{2}+{\omega_{{0}}}^{4}-2\,{\omega_{{0}}}^{2}{\omega}^{2}\\<br /> \mbox{}+{\omega}^{4}}}}\]}
And that's what I'm trying to achieve by hand...
Maple code is
s2s:=((-omega[0]^2+omega^2)*sin(omega*t)+cos(omega*t)*omega*lambda)/(omega^4+(lambda^2-2*omega[0]^2)*omega^2+omega[0]^4);
simplify(convert(s2s,phaseamp,t));
Thanks
Oh, that helps. Note that the denominator is (\omega^2-\omega_0^2)^2+(\lambda\omega)^2. Consider a right triangle with one leg of length \omega^2-\omega_0^2 and the other of length \lambda\omega. Does that help?
Indeed, yes. So easy now. Thanks !
  • · Replies 21 ·
