An electron is placed at Point P, Calculate the Potential Energy
The discussion revolves around calculating the electric potential energy of an electron placed at a specific point in an electric field, with references to relevant equations and values such as net force, net electric field, and electric potential. The subject area includes concepts from electrostatics and electric potential energy.
  • Participants explore how to approach the calculation of potential energy, questioning whether to consider multiple charges and their contributions. There are discussions about the validity of the provided force and electric field values, and some participants express uncertainty about the completeness of the problem statement.
The discussion is ongoing, with participants providing insights into the relationship between electric potential and potential energy. Some guidance has been offered regarding the use of the formula U = qV, and there is an acknowledgment of the need for conceptual understanding. However, there is no explicit consensus on the interpretation of the problem statement.
There are indications of potential confusion regarding the relevance of multiple charges in the problem and the completeness of the information provided. Participants emphasize the importance of clarity in the problem statement to avoid misinterpretation.
aaika
An electron is placed at point P.
Calculate the electric potential energy of the electron in units of Joules
Net Force = 200.97N
Net Electric Field = 2.51e6N/C
Electric Potential at point P = 5.43e6V
Ub-Ua = -qEd
Change in U = -qEd if F is parallel to d
243768
Not quite sure how to approach this question - do I need to calculate -qEd for all three charges and then the electron and add them together?
Thanks
Hi @aaika,
Welcome to Physics Forums!
You're relevant equations look more like given data that would belong in the problem statement.
The Net Force looks suspiciously large. 200 N applied to an electron by an electric field would imply an amazingly large electric field, much larger than what you've specified as the net electric field.
Are you certain that the problem statement is complete and presented exactly as you received it?
gneill said:
Hi @aaika,
Thank you :)
Absolutely certain. The three numbers I provided are the correct answers for the previous questions leading to this one. I have directly copy + pasted the problem so there is no missing information.
But if we take your net electric field value, 2.51e 6N/C, and insert the charge of an electron in the equation ##F = qE##, we arrive at a force value of only about ##4.0 \times 10^{-13} \text{N}##. This contradicts your net force value by a rather large margin. Is the force force value you've given really the force on the electron?
243772
243771
Attached are screenshots of the answers being marked as correct.
Your original problem statement did not indicate that the given values for Net Force and Net Electric Field pertained to other bodies than the electron. How were we to guess? You should always provide the complete problem statement as given.
You have the electric potential at point P. It's units are Volts, which is not a fundamental unit. It is synthesized from Joules/Coulomb (##Volt = \frac{Joule}{Coulomb}##). How do you think you might arrive at the electric potential energy of the electron located at that point?
aaika said:
Problem Statement: An electron is placed at point P.
Relevant Equations: Net Force = 200.97N
Ub-Ua = -qEd
Thanks
The potential energy at any point in space is the product of the "test charge" and the value of the potential at that location, i.e.
U = qV
based on the situation where V at r→∞ is zero.
For the situation where you only have 3 charges as the source charges of the potential field, then the potential potential energy at point P is the work done in moving the electron from very far away (∞) to the point P, i.e. ΔU = U(at p) - U(∞) = U(at p).
Since q = -e and V is given in your problem, this should be straightforward. But you have to have a conceptual understanding of what I described above, because this question can come in a million different varieties.
Zz.
My bad - I thought I included that it was relevant to Q3 when I pasted it.
U = qV
Zz.
Thank you for clarifying! I was caught up in the fact that I had Q1-3 as well as an electron and didn't know whether or not those three Q's would be influential in the formulae to figure it out.
U=qV= (-1.60e-19)(5.43e6) = -8.69e-13J which was correct.
  • · Replies 23 ·
