An initial to general state problem (QM Help)
The discussion revolves around finding the state \(\left|\psi_t\right>\) of a three-level quantum system governed by a specified Hamiltonian. The initial state is given as \(\left|\psi_0\right> = \frac{1}{\sqrt{2}}\left(\begin{array}{cc}1\\1\\0\end{array}\right)\). The participant correctly identifies the eigenvalues of the Hamiltonian as \(E_n = 0, 3, 6\) and derives the unnormalized eigenvectors, later normalizing them. The approach involves expressing the initial state as a linear combination of the normalized eigenvectors and applying the time evolution factor \(e^{-i E_n t}\) for \(t > 0\). The participant confirms their understanding of the procedure, indicating they are on the right track.
Brad_Ad23
1. A 3 level system starts at time t = 0 in the state
\left|\psi_0\right> = \frac{1}{\sqrt2} \left(\begin{array}{cc}1\\1\\0\end{array}\right)
The Hamiltonian is H = 3\left(\begin{array}{ccc}1&0&0\\0&1&1\\0&1&1\end{array}\right)
If \hbar = 1
find the state \left|\psi_t\right> of the system for any time t > 0.
It has been quite a few years since I've done this sort of thing. My approach, perhaps naively, was first to find the eigenvalues for H and then attempt to construct eigenvectors.
I wound up with E_n = 0, 3, 6 for eigenvalues and eigenvectors [un-normalized?] of
<br /> \left(\begin{array}{c}0\\1\\-1\end{array}\right) , \left(\begin{array}{c}1\\0\\0\end{array}\right) , \left(\begin{array}{c}0\\1\\1\end{array}\right)
I am a bit suspicious of the 2nd one, and at any rate I can't seem to remember what happens next (assuming this is the proper approach). I think the eigenvectors should be normalized and then the initial state written as a linear combo of the eigenvectors, with the finale being to add on the basic time-dependence factor of e^{-i E_n t} since h-bar is set to 1 here. Am I on the right approach? If I am or if I am not further help would be appreciated!
Ok, working on it a bit more I think I figured it out (amazing what taking a break for dinner may do).
So I have the unnormalized eigenvectors. If I normalize them I should wind up with:
<br /> \left|s_1\right&gt; = \frac{1}{\sqrt2}\left(\begin{array}{c}0\\1\\-1\end{array}\right)
<br /> \left|s_2\right&gt; = \left(\begin{array}{c}1\\0\\0\end{array}\right)
<br /> \left|s_3\right&gt; = \frac{1}{\sqrt2}\left(\begin{array}{c}0\\1\\1\end{array}\right)
So \left|\psi_0\right&gt; = \frac{1}{\sqrt2}\left|s_2\right&gt; + \frac{1}{2}\left(\left|s_1\right&gt; + \left|s_3\right&gt;\right) = \frac{1}{\sqrt2}\left(\begin{array}{c}1\\1\\0\end{array}\right)<br />
And then to get the general one for some t > 0, I should just put the appropriate exp(iEnt) in front of each eigenvector yes?
looks perfect to me:cool:
  • · Replies 19 ·
  • · Replies 28 ·
