An invariant while crossing the horizon
  • Context: Undergrad
  • Thread starter Thread starter Tomas Vencl
The discussion revolves around the concept of invariance in the context of an observer falling into an evaporating black hole and crossing its event horizon. Participants explore the implications of mass measurements at the moment of horizon crossing and the nature of these measurements in relation to different observers' perspectives.
  • Some participants propose that the mass of the black hole at the moment of horizon crossing, denoted as m_1, can be assigned to that specific event in spacetime.
  • Others argue that while the infalling observer can measure the mass m_1, this measurement is not invariant in a broader sense due to the dependence on simultaneity conventions.
  • A later reply questions the meaning of "crossing the horizon at a finite proper time" without specifying a reference point on the observer's worldline.
  • Some participants assert that all observers can agree on the mass m_1 as computed by the infalling observer, suggesting that this measurement is invariant.
  • However, others challenge this by stating that the mass must be measured locally and that the areal radius is a global parameter, complicating the notion of invariance.
Participants express differing views on the invariance of the mass measurement at the horizon crossing. While some agree that the infalling observer's measurement can be considered invariant, others contend that it is not invariant due to the global nature of certain parameters and the need for local measurements. The discussion remains unresolved with competing perspectives on the nature of these measurements.
Limitations include the dependence on definitions of simultaneity and the distinction between local and global measurements, which are not fully resolved in the discussion.
Tomas Vencl
TL;DR
Is the fact that the infalling observer crossed the horizon at the time when the black hole had mass m_1 an invariant?
While reading the neighboring thread I came up with the following question: consider an evaporating black hole and an observer falling into it. The observer crosses the horizon at a finite proper time \tau_1; at the moment of horizon crossing the black hole has mass m_1 from the infalling observer’s point of view (I understand that the horizon is a global property and the infalling observer may not notice that they have just crossed it; however, retrospectively—e.g. by tracking the beacon of the infalling observer—one can infer which signals continue forever). Is the fact that the infalling observer crossed the horizon at the time when the black hole had mass m_1 an invariant?
What thread? Please give a link.
Yes, that's fine, although the specific value of ##\tau_1## has no meaning off of that observer's worldline.
At the event of the horizon crossing, meaning at the specific point on the infalling observer's worldline where it crosses the horizon, one can assign a "mass" to the hole, yes--it would be the parameter ##m## that appears in the metric. Note that for an evaporating hole, ##m## is not constant, but it does have a definite value at each event in the spacetime.
However, note that this value of ##m## only applies at that particular event.
Only in a very restricted sense: that at that particular event in spacetime, as above, the hole has that mass.
But when you use the phrase "at the time", you might be assuming that we can assign some kind of "time" to the hole having that mass that applies more broadly than just that event, by saying that other events happened "at the same time". We can't, at least not in any invariant sense. Any such thing would be a choice of simultaneity convention, which is not invariant. The only invariant way to know what the mass is at any particular event in spacetime is to look at the value of the parameter ##m## in the metric at that event.
PeterDonis said:
……The only invariant way to know what the mass is at any particular event in spacetime is to look at the value of the parameter ##m## in the metric at that event.
Yes, that exactly is the point of the question.
Tomas Vencl said:
consider an evaporating black hole and an observer falling into it. The observer crosses the horizon at a finite proper time \tau_1; at the moment of horizon crossing the black hole has mass m_1 from the infalling observer’s point of view....
This is tricky even without introducing the complexities of an evaporating black hole. "Crosses the horizon at a finite proper time ##\tau_1##" doesn't make sense unless and until we specify the point on the infaller's worldline where the proper time has been arbitrarily considered to be zero.
But even after we allow for that... "the back hole has mass ##m_1## from the infalling observer's point of view" is an invariant. They somehow measured/calculated the mass and came up with an answer. We all agree about what they measured/calculated (we could even transform to the coordinates they used and repeat the calculation using the values of the measurements they made to get the same answer) which makes it an invariant.
Yes, thank you all. The infalling observer’s proper time (\tau_1) is ultimately not important. What matters is that all observers agree that at the moment the infalling observer crosses the horizon, the black hole had mass m_1 from his point of view. We take this mass to be computed by the infalling observer from the circumference (or area) of the horizon. In other words, all observers agree that the infalling observer crossed the horizon at a specific r_1 (r_1= circumference / 2\pi).
Every measurement is itself an invariant. The observer could record the result and promulgate that round the universe (subject to certain limitations). In any case, no one can disagree about what was recorded.
Yes.
No. The value of the metric parameter ##m## at that event is an invariant. It doesn't depend on any "point of view".
No, we can't, because that is not a local measurement. The observer has to locally measure the value of the parameter ##m## in the metric.
The areal radius ##r## is not a local measurement, since the horizon area is not. It's a global parameter.
  • · Replies 25 ·
  • · Replies 73 ·
  • · Replies 40 ·
  • · Replies 46 ·
9K
  • · Replies 51 ·
  • · Replies 43 ·
