An object is undergoing simple harmonic motion
An object undergoing simple harmonic motion with a period of 1.190 seconds and an amplitude of 0.640 meters was analyzed to determine its position at time t=0.475 seconds. The initial position at t=0 is x=0, leading to confusion regarding the phase shift (∅) in the equation x=Acos(ωt+∅). The correct approach involves using the sine function, x=Asin(ωt), which naturally passes through the origin, thus simplifying the calculation of the position at the specified time.
  • Understanding of simple harmonic motion principles
  • Familiarity with trigonometric functions (sine and cosine)
  • Knowledge of angular frequency (ω) calculations
  • Ability to derive phase shifts in harmonic motion equations
  • Study the derivation of the phase shift formula in simple harmonic motion
  • Learn how to apply the sine function in harmonic motion problems
  • Explore graphical representations of sine and cosine functions in motion
  • Practice solving simple harmonic motion problems with varying initial conditions
Students studying physics, particularly those focusing on mechanics and wave motion, as well as educators looking for effective methods to teach simple harmonic motion concepts.
Mdhiggenz
An object is undergoing simple harmonic motion with period 1.190 and amplitude 0.640
At t=0 the object is at x=0 . How far is the object from the equilibrium position at time 0.475 ?
x=Acos(ωt+∅)
x= 0.640cos(2∏/1.190*.475)=.639
The answer however is .379
What am I doing wrong?
Thank you
- higgenz
Mdhiggenz said:
x=Acos(ωt+∅)
At t = 0, x = 0. What should the value of ∅ be?
You'd be better off modelling the motion as x = Asin(ωt)
Can you explain why you would use sin?
You're told that at t = 0, x = 0. Sketch the curves of x = Asin(ωt) and x = Acos(ωt) with t representing the horizontal axis and x, the vertical. Which of them passes through the origin (0,0)?
It's OK to use the phase-shifted cosine function x = Acos(ωt + ∅) as long as you calculate the value of the phase shift ∅. But you didn't.
I was a bit confused on how to calculate ∅
I know the formula for ∅ is arctan(-vox/ωxo)
But isn't the initial velocity zero which would make it ∅= to 0 ?
Don't get tied up in formulas you memorise. You must clearly understand the derivation of each formula you use, otherwise you'll use them in the wrong context.
Go back to what you wrote. x = Acos(ωt + ∅).
Now put t = 0 and x = 0 to get 0 = Acos(∅). So what should ∅ be?
Use this value of ∅ and try to rework your answer. You'll get a negative value, but it doesn't matter - they just want the numerical magnitude.
Excellent I got the answer than way as well. I appreciate you helping me out, and teaching me an alternative method!
Higgenz
Higgenz
You're welcome. :smile:
  • · Replies 51 ·
