An object travelling away from earth
  • Thread starter Thread starter Mu naught
    Earth
2 replies · 2K views
Mu naught
Say I have an object which has been shot away from Earth at some initial velocity, and I want to find out how long it will take until it's velocity is zero.
If it is moving fast enough, the approximation v = v0 + aΔt doesn't work because the acceleration due to gravity is changing as a function of r. I want to describe v as a function of t, set v equal to zero and solve for t.
This is the attempt I have made to solve this:
[PLAIN]http://img204.imageshack.us/img204/2879/problemw.png
Any suggestions?
Free falling objects in a central gravity field follow an orbit with can be described as a conic section (ellipse, parabola, hyperbola) and you can then relate the distance and speed of the object at any given time to the size of that conical section, [itex]a[/itex] by observing that the specific orbital energy (equal to the total mechanical energy per mass [itex]E[/itex]) of the object is conserved as
(1) [tex]\frac{1}{2}v^2 - \frac{\mu}{r} = E = -\frac{\mu}{2a}[/tex]
where [itex]\mu = GM_{earth}[/itex]. If [itex]E < 0[/itex] the orbit is a bound elliptical orbit and the object will have zero radial speed at farthest point in orbit, called apogee [itex]r_a[/itex] and at its closest point, called perigee [itex]r_p[/itex], and those two distances are related to the size of the orbit by [itex]2a = r_a + r_p[/itex].
It is not clear from your description if you want to shoot the object straight away from the Earth in a recti-linear orbit (i.e. "straight up") where perigee approaches zero or if the object is in a more realistic orbit (inserted from low Earth parking orbit) where perigee is close to the initial distance, but if we assume the last (that is, [itex]r = r_p[/itex]) then you can insert this into (1) and solve to get
(2) [tex]r_a = -\frac{\mu}{E} - r[/tex]
If you really do mean a recti-linear orbit then inserting [itex]r_p = 0[/itex] gives
(3) [tex]r_a = -\frac{\mu}{E}[/tex]
Hope this helps, otherwise feel free to ask. By the way, the subject is very standard and it should be easy to find a more detailed explanation for two-body motion problems in a great number of physical textbooks and on the net.
The answer for distances is a fairly simple polar equation describing a conic section (Circle, ellipse, parabola or hyperbola). That way you can tell the distance of an object in orbit (Either open or close) as a function of the angle relative to the major axis of the curve.The question of time in orbit, however, is a very different, and much more difficult one.
http://en.wikipedia.org/wiki/Free_fall#Inverse-square_law_gravitational_field
It requires quite a bit of knowledge in calculus, and I'm not sure if an analytical solution in elementary functions exists for the case of non-zero initial tangential velocity.
If you know the separation at 0 velocity (Readily available from the energy equation [tex]U/m=-\frac{GM}{y_0}+\tfrac{1}{2}v^2=-\frac{GM}{r_f}[/tex], setting v to 0 to find the distance at which the velocity is 0) then you can calculate the time for the separation to reach that final value starting with an initial separation [tex]y_0=R_{earth}[/tex]
