Analysis - irrational number or positive integer
7 replies · 4K views · last reply
silimay
Let n and k be positive integers. Show that [tex]k^{1/n}[/tex] is either a positive integer or an irrational number.
I set [tex]q = k^{1/n}[/tex]. Then I set [tex]q = \frac{m}{p}[/tex]. (Where m and p don't have common factors.) Then [tex]m^n = k * p^n[/tex]. So then k is a factor of [tex]m^n[/tex].
But here I get stuck. In other proofs they usually show that, like, then k must also be a factor of m, (but I don't know how to do that, if it is true), and then so [tex]m^n =[/tex] an integer * k^2, so then k must also be a factor of [tex]p^n[/tex], which means that m and p do have a common factor.
But I get stuck in the middle.
What are you assuming about m and p, are they positive integers? If so, haven't you assumed q is rational?
StatusX - Thanks so much for the help. If the factor divides m^n, how do I show that it also divides m?
EnumaElish - I am assuming m and p are positive integers with no common factors. So yeah, I have assumed q is rational. I am trying to prove that it cannot be rational (unless k is an nth power).
I think you are close but going about it the wrong way. The easiest way to prove things like this is to assume the opposite.
Suppose q isn’t irrational or an integer.
This means that q can be written in the form of a/b where a and b are relatively prime integers and b is non zero and non 1.
So q = k^(1/n) = a/b.
But this means that k = a^n/b^n
But what did we assume? That a and b are relatively prime, and clearly if a and b are relatively prime so are a^n and b^n. But this means that a^n/b^n isn’t an integer. But we assumed that k is an integer. This leads us to a contradiction, hence our assumption is false. QED.
Now since I gave you a pretty solid outline of the proof, a good way to make sure you really understand it would be to go back and see if you can spot where I used every assumption. Where did I use the fact that a,b and n are integers, where did i use b isn't 1 or 0? etc.
Sorry, I deleted that post because it had a mistake. Just use the prime itself. That is, assume q is a prime factor of k whose power in k is not a multiple of n. Then q must divide m^n, and so clearly also m.
JohnF - Thanks, I think I understand better. That proof makes sense to me.
StatusX - I don't understand how q must divide m if it divides m^n.
