Graduate Analytical function from numerable point set
The discussion centers on the extension of functions initially defined for integers to real variables, exploring whether such extensions can be made unique and smooth (C∞). Examples like the factorial and the power tower function are considered, with the gamma function highlighted as a unique extension of factorials. It is noted that while some functions can be extended, uniqueness often requires additional conditions. The conversation also touches on the use of differential equations and entire functions in this context, indicating that the extension of functions defined on integers to real numbers can be complex and may involve challenges similar to those encountered in Fourier analysis. Overall, the extension of integer-defined functions to real variables remains a nuanced topic in mathematical analysis.
hilbert2
Insights Author
Sometimes there are functions that are initially defined for only integer values of the argument, but can be extended to functions of real variable by some obvious way. An example of this is the factorial ##n!## which is extended to a gamma function by a convenient integral definition.
So, if I have an arbitrary function ##f(x)## for which I know its value for any ##x\in\mathbb{N}##, is it possible to uniquely extend it to ##x\in\mathbb{R}## so that it becomes a ##\mathcal{C}^\infty## function?
Possible examples could be ##f(n) = 1 + 2 + \dots + n##, or the "power tower" function ##f(z,n) = z^{z^{\cdot^z}}## with ##n## ##z##:s in it.
Edit: For the first example it is straightforward to prove by induction that ##f(n) = \frac{n(n+1)}{2}## and then plug any value of ##n## in it, but for the second one it is not as obvious.
Mathematics news on Phys.org
You can always add something like sin(pi x), multiply by cos(2 pi x) and similar things. It can never be unique without additional requirements. As a prominent example, the gamma function can be uniquely defined by the factorials and by being logarithmic convex.
I wonder if, given f(z) for all ## z\in\mathbb{N}##, there is always an entire function in the complex numbers.
Thanks. For a function with initially one real and one integer variable, ##f(x,n)##, I think one approach could be to find the differential equations for which ##f(x,1)##, ##f(x,2)##, and so on, are solutions, and then try to decide a DEs that would naturally produce ##f(x,1/2)## etc. as one solution.
For instance, ##f(x,n) = e^{nx}## is a solution of ##\frac{df(x,n)}{dx} = nf(x,n)## with ##f(0,n) = 1##. Sometimes fractional differentiation could also be of use if it can be shown that ##f(x,n) = \frac{d^n g(x)}{dx^n}## for some known function ##g##.
Edit: Oh, looks like the extention of "power tower" to non-integer heights is discussed here in Wikipedia: https://en.wikipedia.org/wiki/Tetration#Extension_to_real_heights
Svein said:
Thanks. That seems to be for a function defined on an interval of finite length, though. This may cause some problems similar to how a Fourier series becomes a Fourier integral when you try to represent a function defined on whole ##\mathbb{R}## as a linear combination of ##e^{ikx}## terms.
OK. So: Assume a sequence {an} where \sum_{n=1}^{\infty}\frac{1}{\vert a_{n} \vert} is convergent. Then f(z)=z^{m}e^{g(z)}\prod_{n=1}^{\infty}(1-\frac{z}{a_n{}})e^{p_{n}(z)} is an entire function with a zero of order m at the origin and a zero at every an. Each pn(z) is a polynomial of a finite degree and g(z) is an entire function.
Whew!
Comment to my post above: If \sum_{n=1}^{\infty}\frac{1}{\vert a_{n} \vert} is convergent, all the pn(z) ≡ 0 (they are not necessary). If \sum_{n=1}^{\infty}\frac{1}{\vert a_{n} \vert} is not convergent, then the pn(z) are necessary and different from 0.
  • · Replies 16 ·
