Finding the third derivative f'''(6) of a power series
  • Thread starter Thread starter squaremeplz
7 replies · 2K views
squaremeplz
a) determine where f(z) is analytic.
f(z) = sum from n to inf. [ ( (-1)^n * n^2 ) / ( 2^n ) * (z - 6)^n ]
b) evaluate f'''(6)
ratio test
a) I used the ratio test and found that f(z) is analytic on the circle of convergence C: | z - 6 | < 1/2.
b) I found the 3rd derivative of the sum as
f'''(z) = sum from 0 to inf [ ( (-1)^n * n^2 ) / ( 2^n ) * n * (n-1) * (n-2) * (z - 6)^(n-3) ]
then when i plug in 6 into this i get
f'''(6) = 0
any suggestions or comments are much apperciated. thanks
The third derivative of your sum is going to come only from the n=3 term in the sum. It's not zero. (z-6)^(3-3)=1, not zero. And the sum for your third derivative should be the sum from 3 to inf.
ok so
f'''(z) = sum from 3 to inf [ ( (-1)^n * n^2 ) / ( 2^n ) * n * (n-1) * (n-2) * (z - 6)^(n-3) ]
f'''(6) = sum from 3 to inf [ ( (-1)^n * n^2 ) / ( 2^n ) * n * (n-1) * (n-2) * (6 - 6)^(n-3) ]
f'''(6) = sum from 3 to inf [ ( (-1)^n * n^2 ) / ( 2^n ) * n * (n-1) * (n-2) * (0)^(n-3) ]
All the terms vanish except for n=3. I'll say it once more. (z-6)^(3-3)=1.
so f'''(6) = (-1)^3 * (3)^2 / 2^3 * 3 * 2 * 1 * 1 ?
I'm sorry, was my radius of convergence ok?
I didn't look closely at it the first time but no it's not. Why do you think it's 1/2? What did you get from the ratio test for the limit a_(n+1)/a_n?
I did
| (-1)^(n+1) * (n+1)^2 * 1/( 2^(n+1)) * (z-6)^(n+1) * 2^n/( (-1)^n * n^2 * (z-6)^n ) |
= (n+1)^2 * 1 / (2*n^2) * |z-6|
lim n->inf (n+1)^2 * 1 / (2*n^2) = 1/2
so 1/2|z-6| < 1
oh.. did I make the mistake there
|z-6| = 2 ?
also, is this the circle where f(z) is analytic?
thanks!
I did
so 1/2|z-6| < 1
This last line should be [itex]0<\frac{1}{2}|z-6|<1[/itex] and hence the sum converges on the disk [itex]0<|z-6|<2[/itex]...
The ratio test tells you where the sum converges. It so happens that each individual term in the sum is a polynomial in [itex]z[/itex]; hence each term is analytic. That means that the sum will be analytic so long as it exists/converges, and therefor [itex]f(z)[/itex] is analytic on the disk [itex]0<|z-6|<2[/itex]
