Analyzing Forces in a Weightless Beam AO
  • Thread starter Thread starter Femme_physics
    Beam Forces
6 replies · 2K views
Femme_physics
http://img84.imageshack.us/img84/1715/given2.jpg
A weightless beam AO is held in a horizontal position (at the xy plane) as described. At its tip O the ball is attached to a ball joint, and at points C and A its tied via wires. horizontal wire CD and slanted wire AB, whose in the plane parallel to xz. At point E acts on the beam vertical force Q. The shape OKAD is a rectangle (look at the upper view in the drawing).
Given:
http://img35.imageshack.us/img35/9106/given1.jpg
http://img215.imageshack.us/img215/2376/per1v.jpg
http://img845.imageshack.us/img845/9779/per2.jpg
They give out Oz as 0.86666 [kN]. I doubt this could just be a rounding error?
It looks like you got the components of TCD switched in your moment equation.
Did I really? What is the angle from Tcd to the Y axis? It's 60! I reckon I got it right.
Look, I made it more clearly on powerpoint so you'll see exactly what I'm seeing
http://img11.imageshack.us/img11/7708/metersandeverything.jpg
According to the axes, I used the right distances and angles
Hint: You can calculate the moment about O due to TCD more simply since you know the angle between the lever arm and the force.
but I don't have to use the diagonal distance.
Yeah, I think you are right. It's just a calculation error then. I haven't been able to reproduce your answer from your equation. I get [itex]T_{CD}=\sqrt{3}~\mathrm{kN}[/itex].
I have no idea what you mean. The torque τ is just τ = rF sin θ = (0.6 m)TCD sin 60.
Thanks :smile: I "think" I solved it. I'll post my full solution this evening scanned. Only Oz is different. I noticed the solution manual makes it out to be 1.5 kN, whereas it really should be 0.9 kN
