What Is the Angle Between Two Vectors if Their Magnitudes Are Equal?
  • Thread starter Thread starter quietrain
    Angle Vectors
The angle between two non-zero vectors A and B, where the magnitudes are equal and |A+B| = |A| = |B|, is definitively 120 degrees. This conclusion arises from the application of the inner product and geometric reasoning, specifically the parallelogram rule. The misconception that the angle could be 60 degrees stems from an incorrect interpretation of vector addition. The correct analysis shows that the vectors form an isosceles triangle, confirming the angle of 120 degrees.
  • Understanding of vector addition and properties
  • Familiarity with inner products in vector spaces
  • Knowledge of the parallelogram rule in geometry
  • Basic trigonometry, specifically cosine functions
  • Study the properties of vector addition and subtraction
  • Learn about the inner product and its applications in vector analysis
  • Explore the geometric interpretation of vectors and angles
  • Investigate the parallelogram law and its implications in vector mathematics
Students of mathematics, physics, and engineering, particularly those studying vector analysis and geometric interpretations of vectors.
quietrain
if |A+B| = |A| = |B|
then what is the angle between A and B?
A and B are vectors.
edit: assume they are non-zero vectors
the only way this is possible is if the angle is 60degrees right? equilateral triangle.
but the ans given is 120 degrees. why?
if it is 120 degrees, then it would be isosceles triangle and the magnitude of A+B won't be equal to A or B anymore.
so is the ans given wrong?
thanks!
thanks!
We can use norms to do this as well as inner products.
|A+B|^2 = <A+B,A+B> = <A,A+B> + <B,A+B> = <A,A> + 2<A,B> + <B,B> = <B,B> = <A,A>
From the above we have the following relationships:
<A,A> + 2<A,B> + <B,B> = <A,A> = <B,B>
2<A,B> + <B,B> = 0
2<A,B> + <A,A> = 0
<A,A> = <B,B> = 0
This implies that A and B are the zero vectors and that they have no angle since they have no length.
2<A,B> + <B,B> = 0
2<A,B> + <A,A> = 0
<A,A> = <B,B> = 0
oh erm, assuming A and B are non zero?
Ohh **** I made a big mistake.
Ok so going from
2<A,B> + <A,A> = 0
2<A,B> + <B,B> = 0
So
2<A,B> = -<A,A> = -<B,B>
<A,B> = -<A,A>/2 = -<B,B>/2
<A,B> = |A||B|cos(theta)
= -|A|^2/2
= -|B|^2/2
But since |A| = |B| we can use
<A,B> = -|A||B|/2
= |A||B|cos(theta)
cos(theta) = -1/2
this implies theta = 120 degrees or 2(pi)/3
Hopefully that's right
Another way to arrive at the same answer is to use a geometric argument like you did with the equilateral triangle. The issue with your reasoning is that the angle between two vectors is usually defined as the angle formed when the vectors are connected "tail-to-tail", rather than "head-to-tail" like when they are arranged to form a trange:
[PLAIN]http://img822.imageshack.us/img822/1200/vectorsh.jpg
ah i see thanks a lot everyone
thanks!
You are looking at the "parallellogram rule" wrong. If A and B have their endpoints at the point, P, then the vector from the "tip" of A to the "tip" of B would be B- A, not A+ B.
To get "A+ B" you have to move the "tail" of A to the "tip" of B (or vice-versa) and if you actually draw this, you will see that the angle between the two vectors is now 120 degrees, not 60.
yup thanks i understand now
  • · Replies 24 ·
  • · Replies 16 ·
