Angular Acceleration of a centrifuge
The discussion focuses on calculating the constant angular acceleration of a centrifuge that rotates at 3400 rev/min and makes 48 revolutions before stopping. The initial angular speed is converted to radians per second, resulting in 356 rad/sec. Participants emphasize the importance of using the correct rotational kinematic equations, particularly relating angular displacement to angular acceleration. There is confusion regarding time conversion and the proper units for acceleration, with clarification that the acceleration should be negative due to deceleration. Ultimately, understanding the relationship between linear and rotational kinematics is crucial for solving the problem accurately.
vipertongn
A centrifuge in a medical laboratory rotates at an angular speed of 3400 rev/min. When switched off, it rotates 48.0 times before coming to rest. Find the constant angular acceleration of the centrifuge.
Relevent equations: ωf = ωi + αt
My work:
I found out the time by (48 rev)(1min/3400 rev)(60 sec/min) = 0.847 seconds
I then converted the rev/min to rad/sec (3400 rev/min)(2pi/1rev)(1min/60sec)= 356 rad/sec
So I set the problem up like 0=356 rad/sec + α(0.847 seconds)
-356/0.847=α
α = -420 rad/s^2
yes but couldn't you find time using the equation i did earlier? I'm trying to solve for a tho...
However, if I were to calculate what you put in...
0=3400 rev/min+2a(48rev)
-3400/96=a
a=-35 min^-1
Yes. You can use that equation for time, once you've found the α based on the θ given and the initial ω.
i edited my last post, is that correctly calculated?
Well I left an exponent out of my earlier post and I corrected that apparently after you used it.
Instead of blindly using formulas, I encourage you to review the link and think about how the rotational kinematic equations relate to the regular one dimensional kinematics that I think you already know.
But that aside (and the exponent of the initial ω corrected) your calculation hasn't accounted for the conversion from min to sec. (Unless you don't need your answer in sec.)
if i put it in seconds it ends up being 0.583 s^-1 but that' can't be the acceleration...shouldn't it be to the -2?
Look you need to understand the equations.
ωf2 = ωi2 + 2*α*θ
But they give you revolutions. And there are 2π radians in a revolution and θ is in radians.
ohhhh i see now, thanks lowly ^^
Remember the acceleration α they want is (-) because you are slowing down to a stop.
14K
