Angular acceleration x radius= Acceleration of center of mass ?
The discussion centers on the relationship between angular acceleration and linear acceleration in rotating bodies. It clarifies that angular acceleration multiplied by radius gives the tangential acceleration of a point on the body, not the acceleration of the center of mass. The correct formula is atan = αr, where atan is the tangential acceleration, α is angular acceleration, and r is the distance from the axis of rotation. The relationship acm = αr applies only when a body is both rotating and translating, such as a sphere rolling without slipping. Misunderstandings arise regarding the definitions and contexts of these terms, particularly the distinction between center of mass and center of rotation.
AakashPandita
For a rotating body,
(angular acceleration x radius)= Acceleration of center of mass ?
But a rotating body can have angular acc. even if it is not translating. what is wrong?
no no no... angular acc. x radius = the linear acc. of a point on the body , ie the tangential velociti of that point with respect to the centre of mass
Likes 1 person
the point is moving around the body with a speed= R x α
where α= angular acceleration
Hi Aakash...
The correct relationship for a point on a rotating body is
atan = αr where ,
atan=tangential acceleration of the point with respect to center of the axis
α = angular acceleration of the rotating body
r= distance between the point and the center of the axis
The relationship acm = αr is a constraint which is sometimes obtained in cases when a body is rotating as well as translating.
For eg. a sphere rolling without slipping on floor .
Tanya Sharma said:
Hi Aakash...
atan = αr where ,
i have told the same...:cool:
Your language is sloppy and inaccurate .
The item in red should be acceleration.
Again ,instead of center of mass,you should have used center of rotation.
That doesn't make any sense . Neither the point is moving around the body ,nor is speed equal to R x α
Likes 1 person
thanks.
  • · Replies 30 ·
  • · Replies 19 ·
