How to Determine Angular Deceleration and Initial Speed of a Coasting Saw Blade?
The discussion focuses on calculating the angular deceleration and initial speed of a coasting circular saw blade that completes 1200 revolutions in 40 seconds. Using the equation for angular displacement, the initial angular speed is determined to be 30 RPM. The angular deceleration is calculated using the final velocity of 0 RPM and the time of 40 seconds, resulting in an angular deceleration of 0.75 RPM/s. These calculations assume constant deceleration throughout the coasting period.
  • Understanding of angular motion equations
  • Familiarity with the concepts of revolutions per minute (RPM)
  • Basic knowledge of kinematics
  • Ability to perform unit conversions between rev/s and RPM
  • Study the kinematic equations for rotational motion
  • Learn about angular acceleration and its applications
  • Explore unit conversion techniques between different rotational speed metrics
  • Investigate practical applications of angular deceleration in machinery
Engineers, physics students, and anyone involved in mechanical design or maintenance of rotating machinery will benefit from this discussion.
Lance WIlliam
A circular saw blade completes 1200 revolutions in 40s while coasting to a stop after being turned off. Assuming constant deceleration, what are (a) the angular deceleration and (b) the initial angular speed?
Answer in RPM/S
Method I used: Change in theta is 1200
Time: 40s
final Vel.:0
Initial Vel.:?
Alpha:? Eqn Used: (change in theta)=(1/2)(Initial vel.+final vel.)*time
looking for inital speed:
1200=(1/2)(initial vel+0)40seconds
Take the vel. found and place into eqn:
looking for alpha:
final vel. =Initial vel.+alpha*time
I ended up getting 1.5 ...
This will give you the angular speed in rev/s.
looking for alpha:
That will give you alpha in rev/s/s, not RPM/s like they want. (Convert the speed to RPM--rev/min, instead of rev/s.)
  • · Replies 54 ·
23K
9K
