Angular Accerlation Homework: Avg. Angular Acc in Rad/s2
  • Thread starter Thread starter cstout
    Angular
To find the average angular acceleration of a hard disk spinning at 7200 rpm, starting from rest and taking 3.7 seconds to reach that speed, the correct formula is α = Δω / Δt. The user initially attempted to apply an incorrect equation, leading to confusion about their answer being marked wrong. Clarification was provided that the change in acceleration over time does not apply in this scenario. The discussion emphasizes the importance of showing work to identify errors in calculations. Understanding the correct application of angular acceleration formulas is crucial for solving such problems.
cstout
During normal operation, a computer's hard disk spins at 7200 rpm. If it takes the hard disk 3.7 s to reach this angular velocity starting from rest, what is the average angular acceleration of the hard disk in rad/s2?
Change in Angular Accerlation/ Change in time
I tried the above equation but the online homework says the answer is wrong. I'm not sure of what else to do.
If you don't show your work, how can we know where you went wrong?
Also, your equation given is not an equation (there is no equal sign), but either way, change in acceleration/change in time is a rate of change of acceleration, which would not help you here. Did you mean this?
\alpha=\frac{\Delta \omega}{\Delta t}
  • · Replies 19 ·
  • · Replies 20 ·
