Angular Frequency vs. Angular Velocity
In simple harmonic motion (S.H.M.), angular frequency (ω) is typically expressed in radians per second, where the period T is calculated using the formula T = 2π/ω. The confusion arises when determining whether to use π as 3.14 or as a conversion factor for degrees, as π is a numerical constant and not equal to 180 degrees. When ω is given in degrees per second, the correct formula becomes T = 360/ω. It's essential to clarify whether the problem specifies radians or degrees to apply the correct formula. Understanding these distinctions is crucial for solving related problems accurately.
gracy
In S.H.M omega denotes?I am really confused where to put pi=3.14 and where to put pi=180 degrees.In one question while solving for omega when Time period is given from formula T=2pi/omega i took pi=3.14 and got right but in other question in similar situation i.e solving for omega when Time period is given from formula T=2pi/omega ,when i took pi=3.14 i got wrong when i saw solution i came to know that there has to be pi=180 degrees.I am really confused.where omega is radian per second and where it is only per second?And where to put pi=3.14 and where to put pi=180 degrees in formula T=2pi/omega?
I would think that either the question itself, or your instructor, should be telling you whether to do the problem in radians or degrees.
In one question while solving for omega whenTime period is given from formula T=2pi/omega i took pi=3.14 and got right but in other question in similar situation i.e solving for omega when Time period is given from formula T=2pi/omega ,when i took pi=3.14 i got wrong when i saw solution i came to know that there has to be pi=180 degrees.I am really confused.
Repeating what you've already said without giving any more information isn't going to help anyone help you. What exactly do the questions say?
pi is never equal to 180 degrees; pi is a number. Angular frequency, ##\omega##, is usually given in radians/sec. In that case, the period is given by ##T = 2 \pi/\omega##. If angular frequency is given in degrees/sec, then you'd have to use ##T = 360/\omega##.
Note that ##2\pi## is the number of radians in a complete cycle and 360 is the number of degrees in a complete cycle.
Likes gracy
For simple comparison, I think the same thought process can be followed as a block slides down a hill, - for block down hill, simple starting PE of mgh to final max KE 0.5mv^2 - comparing PE1 to max KE2 would result in finding the work friction did through the process. efficiency is just 100*KE2/PE1. If a mousetrap car travels along a flat surface, a starting PE of 0.5 k th^2 can be measured and maximum velocity of the car can also be measured. If energy efficiency is defined by...
  • · Replies 20 ·
  • · Replies 21 ·
19K
  • · Replies 20 ·
