Angular momentum and Quantum Number l
The discussion revolves around calculating the quantum number l for a system of two masses connected by a rigid rod, rotating about their center of mass. The moment of inertia is calculated using the formula I = Σmiri², leading to a value of 1.25 x 10^-9 kg m². The angular momentum L is then determined using L = I * ω, resulting in a value that suggests l is on the order of 10^55, raising concerns about the accuracy of the calculations. Participants debate the correct application of formulas for moment of inertia and the significance of the rod's mass. The conversation highlights the complexity of accurately determining quantum numbers in rotational systems.
krawls30
Move here from another forum, so no homework template.
The question: Consider two masses of 0.1 gm each, connected by a rigid rod of length 0.5 cm, rotating about their center of mass with an angular frequency of 800 rad/s. a.) What is the value of l corresponding to this situation? b.) What is the energy difference between adjacent l-values for the l you have just calculated?
Relevant equations:
Moment of Intertia about center of mass = ∑miri
L=I * ω
L= ħ[l(l+1)]1/2
My attempt at part a of the problem:
r= 0.0025m
mass= 0.0001 kg
I = 2 * (0.0001 kg) * (0.0025 m2) = 1.25 * 10-9 kg m2
L = 1.25 * 10-9 kg m2 * 800 rad/s
L/ħ = 9.48*1027 = [l(l+1)]1/2
Which this is the answer, but when I solve for l(the quantum number for angular momentum) I get a number with order of magnitude of 1055 am I completely overlooking something here? I can't think of any other ways to solve this problem. Thank you in advance for your help!
Are you sure this is correct?
I think so... I used this website http://socratic.org/questions/how-do-you-find-moment-of-inertia-of-two-point-masses
Look again, that gives the another formula than what you wrote
Well I also tried 1/12 ML2 but that still isn't working.
No you have to square the radius. I = mr^2, not mr.
I don;t see that on the page
OH that's my mistake, that was a typo it's supposed to be Σmiri2
If you don't know the mass of the ord you can't use the second equation because M is the mass of the rod
it's a rigid body.. so the mass of the rod is being ignored
16K
  • · Replies 54 ·
  • · Replies 18 ·
