Angular momentum at a distance
The discussion revolves around calculating the angular momentum of a complex object at a distance from a reference point P, considering its moment of inertia, mass, velocity, and angular velocity. Participants explore different formulations and corrections related to the angular momentum of rigid bodies and systems of particles.
  • One participant suggests that the angular momentum about point P can be approximated as \(\vec{L} = \vec{r} \times M\vec{v}\), questioning its accuracy.
  • Another participant argues that this approximation is insufficient for complex objects, noting that the moment of inertia should be expressed as \(I = cMR^2\) where \(c\) is a constant specific to the object's geometry.
  • A third participant emphasizes the need to include the object's own angular momentum, providing a formula that relates the angular momentum about point P to that about the center of mass and the displacement vector from P to the center of mass.
  • One participant expresses gratitude for the clarification and inquires about a proof for the discussed concepts.
  • Another participant later claims to have proven the relationship discussed, providing a detailed derivation for the angular momentum of a system of particles.
  • A final participant acknowledges the clarity of the proof provided, comparing it favorably to their own derivation.
Participants express differing views on the accuracy of the initial approximation for angular momentum, with some advocating for a more nuanced approach that includes the object's own angular momentum. The discussion includes both agreement on the need for corrections and varying interpretations of how to express angular momentum for complex objects.
The discussion highlights the complexities involved in calculating angular momentum for non-simple objects, including the dependence on the object's geometry and the definitions of center of mass. Some mathematical steps and assumptions remain unresolved.
tmiddlet
Say I have a situation like the image.
I have a potentially complex object with moment of inertia I about its center of mass, mass M, velocity v and position r with respect to P. It is rotating with angular velocity ω about its center of mass
What is the angular momentum about point P? I would say [tex]\vec{L} = \vec{r} \times M\vec{v}[/tex] but would that be accurate or only an approximation?
I think L=r*m*v is an approx because what you did is that you Used L=w*I where I was substuted as I=MR^2 which is the Inertia for a point mass .If the object is a complex its Inertia would be I=cMR^2 where c is a constant (example for Rod rotating about its tip I =1/3*MR^2 , c= 1/3 ) therefore exact L for complex won't equal r*Mv :)
You should remember to include the objects "own" angular momentum. If the angular momentum around the CM of an object is LCM then the angular momentum of the body for any other reference point P is
LP = LCM + rP x mv,
where rP is the displacement vector from P to CM. This equation is exact in the sense that follows from the definitions of angular momentum and center of mass. If you know the object to be rigid you can further use LCM = Iω.
Thanks a ton! This is exactly what I was looking for.
Do you know of a proof of this?
Never mind, I managed to prove it. Thanks!
It's pretty simple for a system of particles. Let
[itex]\mathbf r_n[/itex] be the vector from the center of mass to nth particle,
[itex]m_n[/itex] be the mass of the nth particle,
[itex]\mathbf R[/itex] be the vector from the origin to the center of mass, and
[itex]M[/itex] be the total mass of the system, [itex]M=\sum_n m_n[/itex].
Note that [itex]\sum_n m_n \mathbf r_n = 0[/itex] by definition of the center of mass.
The angular momentum of the system of particles with respect to the center of mass is
[tex]L_{CoM} = \sum_n m_n \mathbf r_n \times \dot{\mathbf r}_n[/tex]
The angular momentum of the system of particles with respect to the origin is
[tex] \begin{aligned}<br /> L &= \sum_n m_n (\mathbf R+\mathbf r_n) \times (\dot{\mathbf R}+\dot{\mathbf r}_n) \\<br /> &= \sum_n m_n\mathbf R\times\dot{\mathbf R} +<br /> \sum_n m_n\mathbf R\times\dot{\mathbf r}_n +<br /> \sum_n m_n\mathbf r_n\times\dot{\mathbf R} +<br /> \sum_n m_n\mathbf r_n\times\dot{\mathbf r}_n \\<br /> &= \mathbf R\times M\dot{\mathbf R} +<br /> \mathbf R\times\frac{d}{dt}\left(\sum_n m_n\mathbf r_n\right) +<br /> \left(\sum_n m_n\mathbf r_n\right)\times \dot{\mathbf R} +<br /> L_{CoM}<br /> \end{aligned}[/tex]
The sum [itex]\sum_n m_n\mathbf r_n[/itex] vanishes by definition of center of mass and thus
[tex]L = \mathbf R\times M\dot{\mathbf R} + L_{CoM}[/tex]
Thanks. That was the same as mine but much neater.
  • · Replies 30 ·
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 16 ·
