How Does Throwing Gum Affect Angular Momentum and Speed of a Spinning Slab?
The discussion revolves around a problem involving a rectangular slab that can spin about its center, with participants analyzing the effects of throwing wads of bubble gum at various paths on the slab's angular momentum and speed. The focus is on understanding angular momentum and torque in this context.
  • Participants discuss the ranking of paths based on angular speed after the gum sticks, with some expressing uncertainty about how to approach the problem. Questions about torque and its relationship to angular momentum are raised, along with specific inquiries about the calculations involved.
There is an ongoing exploration of the relationships between torque, angular momentum, and angular speed. Some participants have provided insights into the calculations for torque based on different paths, while others are questioning their understanding of the concepts involved. No explicit consensus has been reached regarding the final ranking of the paths.
Participants are working under the assumption that the slab is initially at rest and are considering the implications of torque being zero for certain paths. There is also a mention of the time of impact being the same for all cases, which may influence their calculations.
snoggerT
The figure below shows an overhead view of a rectangular slab that can spin like a merry-go-round about its center at O. Also shown are seven paths along which wads of bubble gum can be thrown (all with the same speed and mass) to stick onto the stationary slab.
(a) Rank the paths according to the angular speed that the slab (and gum) will have after the gum sticks, greatest first (use only the symbols > or =, for example 1=2=3>4>5>6=7).
L=Iw
- I'm really not sure how to start on this problem. I'm struggling with angular momentum as a whole, but I think if I can get a better understanding of this problem, I'll have a better understanding of angular momentum as a whole. So I guess I just need some pointers on how to view this problem
Use torque... the magnitude of the torque is the force times the perpendicular distance from the line of the force to the pivot...
The magnitude of the force exerted is the same in all direction... call the long side L, the short side s...
call the force F...
What is the magnitude of the torque due to number 2?
call the force F...
- The magnitude of #2 would be 0.
exactly... same way #3 and #5 are 0. So 2, 3 and 5 are the lowest...
how about 4,6,7 and 1 ?
- I would say that 6 is the greatest. Followed by 4 and then 7 and then 1 being the least. I'm not sure if that's correct though.
Don't guess.
What is the torque of 6... call the force F... long side L... short side s...
Don't guess.
My problem is with L and s. I know that torque is rXF and that in this case it would be rF(perpendicular)sin(theta). For 6, it's perpendicular to the origin, so sin90=1. Therefor to solve 6 it would just be rF(perpendicular). I just don't know how to find r since I don't know the position of the origin (whether it's in the middle of the block or not).
the magnitude of torque is |r X F| = rFsin(theta) which is rperpendicular*F or r*Fperpendicular (meaning that rsin(theta) is rperpencular... Fsin(theta) is Fperpendicular)
here I think rperpendicular*F is more convenient...
so for 6 rperpendicular is L/2. so magnitude of torque is FL/2.
- I just realized I thought the "O" in the picture was the origin and didn't see the dot next to it (that is really the origin). So the rest would be:
4> F*(sqrt((L/2)^2+(s/2)^2))
7> Fs/2
1> I'm unsure on this, but from looking at the picture. It appears that it would be Fs/4.
7> Fs/2
Everything looks right.
I agree with you about 1 having Fs/4
also note that (sqrt((L/2)^2+(s/2)^2)) is greater than both L/2 and s/2.
So now what is the final answer from greatest to least.
- So the torque's would be the same as the angular speed that the question is asking? also, how would that relate to angular momentum? The 2nd part of the question is which of them have angular momentum of zero.
Torque gives the rate of change of angular momentum. Assuming the slab is initially at rest... the greater the torque, the greater the rate of change of angular momentum...
torque*(delta t) = final angular momentum - initial angular momentum
delta t is the time of impact... (time during which the force is exerted on the slab). we assume the delta t is the same for all 7 cases...
So the greater the torque, the greater the angular momentum and hence the angular speed...
If torque is 0... that means that the angular momentum doesn't change at all... so it stays at an angular momentum of 0.
