What is the Angular Momentum of a Bent Plate Rotating at 30rad/sec?
To determine the angular momentum of a bent plate rotating at 30 rad/sec around the z-axis, the mass density is given as 70 kg/m². The calculation involves using the moment of inertia and the angular velocity, applying the parallel axis theorem to adjust for the rotation axis. The discussion highlights the need for clarity in the problem-solving approach, emphasizing the importance of detailing the steps taken in calculations. Participants encourage sharing specific attempts to better address confusion. The focus remains on accurately calculating the angular momentum using the provided parameters.
max1546
The bent plate has a mass of 70kg per square meter of surface area and revolves about the z-axis at the rate w=30rad/sec. Determine the angular momentum H of the plate about the z-axis. (Neglect the mass of the hub and the thickness of the plate)
http://img839.imageshack.us/img839/9853/angularmomentum.jpg
w=w k
HG=-Izzwzi-Izywzj+Izwzk
Splitting the bodies into various parts and calculating. However, as it is about the axis, and not the point, confused.
You would use the parallel axis theorem to move the moments of inertia from centroidal points to the axis of rotation. Then determine the angular momentum.
Show us what you actually did. It's hard to figure out what's confusing you if all you give us is a vague description of what you tried.
