Angular momentum of time dependent particle motion
9 replies · 9K views · last reply
Schulze
A particle of mass m moves in a circle of
radius R at a constant speed v. Assume: The
motion begins from the point Q, which has
coordinates (R, 0).
Determine the angular momentum of the
particle about point P, which has coordinates
(−R, 0) as a function of time.
The answer choices can be found at: http://imgur.com/GxVLhGb
v = Rω
L = R x p = Rpsin(θr,p) = Rmv(sinθr,p)
θf = θi + (ωit)
θf = θi + (vt/R)
L1 at position Q = R x p = Rpsin(θr,p) = Rmv(sinθr,p)
L2 at position P = R x p
L2 at position P = Rpsin(-θr,p)
L2 at position P = Rmv(-sinθr,p)
L2 at position P = Rmv(sin((vt/R)+∏)))
However all answers have Rmv(____ + 1) factor. Which I do not have. Therefore I have reason to believe that my answer is incorrect.
My guess is that the answer is Rmv(sin((vt/R)+∏))+1)
1. Make a drawing
2. Realize that L = r X p is NOT Rmv(sinθr,p) but that ##\vec L= \vec r(t) \times \vec p(t)##: all the answers are vectors!
3. Make a distinction between angular momentum about the origin and angular momentum about point (-R, 0)
I did all those things but I thought that this site didn't want me to post a poorly drawn sketch. Furthermore, I am not very good at using Latex to make my equations look nice and bold and whatnot.
Nor am I very efficient at using this yet so bare with me.
Also, L2 will be in the opposite direction of L1; and I believe that the alternate statement for the cross product of a X b = absin(θ) accounts for this. Where a, and b are the magnitudes of the vectors of a and b.
One thing at the time. Let's try a few simple tings:
What is the magnitude of Labout the origin at t=0 ?
What is the magnitude of Labout the origin at t=v/(##\pi##R) ?
What is the magnitude of Labout P at t=0 ?
What is the magnitude of Labout P at t=v/(##\pi##R) ?
Do you have an expression for ##\vec r(t)## ?
Ah, I get the impression you have difficulty with
* distinguishing Labout (0,0)(t) from Labout (-R,0)(t)
* interpreting r x p
What do you mean with L1 and L2 ?
Hello Schulze
Your guess is incorrect .
Look at the figure attached .O is the origin.The coordinates of Q are ##R \hat{i}## whereas the coordinates of P are ##-R \hat{i}## .Let the particle be at M at any time 't' making an angle θ with the horizontal.
All you have to do is calculate ## m(\vec{PM} \times \vec{v})## .
1. First express θ in terms of v,R,t .
2. Write down the coordinates of M .
3. You already have coordinates of P given . So calculate ## \vec{PM}##
4. Find the component of velocity at point M in 'x' and 'y' direction . From that express velocity vectorially .
Now perform the cross product . Be careful with trigonometric identities .You will get the elusive 1 .
  • Diagram of a particle M moving counterclockwise on a circle of radius R centred at O, with diameter PQ on the horizontal axis, velocity v tangent at M, and angle θ measured at O from the horizontal.
That impression would be correct.
A friend of mine told me the right answer but wouldn't tell me how to arrive at this result. So that that is my next aim.
Answer: L = (mvR) cos((vt/R) + 1)
Well, in that case we won't be needing the drawing I had already prepared when Tanya beat me to it :frown:.
For the sake of others listening in: what did you do and how did you do it ?
[itex]\vec{L}[/itex] = [itex]\vec{r}[/itex] [itex]\times[/itex] m[itex]\vec{v}[/itex]
The angular displacement around the circle:
θ = ωt = [itex]\frac{vt}{R}[/itex]
The vector from the center of the circle to the mass is then:
Rcos(θ)i + Rsin(θ)j (in the i and j directions)
The vector from the point P to the point of the mass is:
[itex]\vec{r}[/itex] = R[itex]\hat{i}[/itex] + Rcos(θ)[itex]\hat{i}[/itex] + Rsin(θ)[itex]\hat{j}[/itex]
[itex]\vec{r}[/itex] = R[[1+cos([itex]\frac{vt}{R}[/itex])][itex]\hat{i}[/itex] + sin([itex]\frac{vt}{R}[/itex])[itex]\hat{j}[/itex]
The velocity vector
[itex]\vec{v}[/itex] = -vsin([itex]\frac{vt}{R}[/itex])[itex]\hat{i}[/itex] + vcos([itex]\frac{vt}{R}[/itex])[itex]\hat{j}[/itex]
So,
becomes
[itex]\vec{L}[/itex] = m v R {[1 + cos(ω t)][itex]\hat{i}[/itex] + sin(ω t)[itex]\hat{j}[/itex]}
× [− sin(ω t)[itex]\hat{i}[/itex] + cos(ω t)[itex]\hat{j}[/itex]]
= m v R {[1 + cos(ω t)] [cos(ω t)] −[sin(ωt)] [− sin(ω t)] }[itex]\hat{k}[/itex]
= m v R [cos([itex]\frac{vt}{R}[/itex])] + 1][itex]\hat{k}[/itex]
