Angular Momentum: Solving Homework Confusion
Angular momentum is a key concept in solving problems related to rotational motion, particularly when it comes to calculating final angular velocity. The relationship between kinetic energy and angular momentum is highlighted through the equations KE(rotational) = 1/2Iw^2 and Angular momentum = Iw. In this context, only angular momentum is conserved, which simplifies the calculations. Understanding that conservation of angular momentum allows for changes in kinetic energy to be related to final angular velocity is crucial. Clarity on these principles can resolve confusion in homework problems involving angular momentum.
Litcyb
I am just confused about Angular momentum.
KE(rotational)= 1/2Iw^2
Angular momentum= Iw
Why can I do the change in KE rotational to calculate the her final angular velocity in 3 revs?
very confused! :( both equations relate to moment of inertia and angular velocity.
Only angular momentum is conserved here. That's all you need.
  • · Replies 17 ·
  • · Replies 30 ·
15K
  • · Replies 19 ·
  • · Replies 22 ·
