Angular velocity and angular momentum
3 replies · 10K views · last reply
Northbysouth
A turntable has a radius of 0.80 m and a moment of inertia of 2.00 kg • m2. The turntable is rotating with an angular velocity of 1.50 rad/s about a vertical axis though its center on frictionless bearings. A very small 0.40-kg ball is projected horizontally toward the turntable axis with a velocity of 3.00 m/s and is moving directly towards the center of the table. The ball is caught by a very small and very light cup-shaped mechanism on the rim of the turntable (see figure). What is the angular velocity of the turntable just after the ball is caught
L= Iw
The inertia of the turntable = 2.0 kgm^2
The inertia of a solid sphere = 2/5*M*R^2
Li = initial angular momentum
Lf = final angular momentum (momentum after the ball is caught)
Lid = initial angular momentum of the disc
Lip = initial angular momentum of the particle
Lfd = final angular momentum of the disc
Lfp = final angular momentum of the particle
wft = angular velocity of the turntable after the ball is caught
I assumed that Li = Lf
Li = Lid + Lip
Li = 2.0kg*1.50 rad/s + 0
Li = 3.50 kgm^2
Similarly, I thought that:
Lf = Lfd + Lfp
Lf = 2.0kgm^2/s*wft + 2/5*0.4kg*0.80^2*wft
3.50kgm^2/s = 2.1024wft
wft = 1.66476 kgm^2/s
As you can see this isn't an answer choice. Is it wrong for me to assume that the angular velocity of the particle after it is caught is the same as that of the turntables angular velocity?
  • Diagram of a rotating turntable with radius 0.80 m, moment of inertia 2.0 kg•m², angular velocity 1.5 rad/s, and a cup on its rim; below it a small ball of 0.40 kg moving upward at 3.0 m/s.
I'm not too sure if I'm right, but hopefully this is one of the answer choices.
After the collision, the ball and the turntable should be turning together.
Ii*Wi=If*Wf
You can just add up the moments of inertia, so:
If=Turntable Moment + Ball Moment
The ball is small enough that we can treat it like a point particle (I see that you multiplied by 2/5, but that only works whenever the axis of rotation is through the diameter of the sphere, in this case the axis of rotation is a radius r from the ball), so ball moment=m*r^2
2.00*1.5=(2.00+0.4*0.8^2)*Wf
Wf=3/(2.256)
Wf=1.33
Please let me know if that's an answer.
Yes that is an answer. Thank you
The choices, which I forget to put in my original post are:
A) 1.33 rad/s
B) 0.75 rad/s
C) 0.30 rad/s
D) 0.50rad/s
E) 0.94 rad/s
Alright cool.
It looks like you just accidentally multiplied 2*1.5 incorrectly, and used the wrong moment of inertia for the ball.
