Angular velocity and energy lost due to friction
The discussion focuses on a physics problem involving a 3.0 m diameter merry-go-round with a rotational inertia of 120 kgm², initially spinning at 0.50 rev/s. When four 25 kg children sit on the edge, the new angular speed is calculated to be 0.17 rad/s, using the conservation of angular momentum. The total energy lost due to friction during this interaction is determined to be 10 kgm²rev/s, which converts to -20π kgm²rad/s. The calculations utilize key principles such as conservation of angular momentum and rotational mechanical energy.
  • Understanding of angular momentum conservation
  • Familiarity with rotational inertia calculations
  • Knowledge of rotational kinetic energy equations
  • Ability to convert between revolutions per second and radians per second
  • Study the principles of conservation of angular momentum in closed systems
  • Learn about the effects of external torque on rotational motion
  • Explore the relationship between rotational kinetic energy and work done by non-conservative forces
  • Investigate the conversion between different units of angular velocity
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to enhance their understanding of angular momentum and energy conservation principles.
mossman
the problem is: A 3.0 m diameter merry go round with rotational inertia 120kgm^2 is spinning freely at 0.50 rev/s. Four 25kg children sit suddenly on the edge of the merry go round. a) Find th new angular speed, and b) detrmine the total energy lost to friction between the children and merry go round.
conservation of angular momentum = L_initial = L_final
angular momentum = Iomega^2
conservation of rotational mechanical energy = KE_final - KE_initial = 0 + W_nonconservative
So, r = 1.5m, I_wheel = 120 kgm^2, omega_wheel = 0.5 rev/s, and since when the children jump onto the wheel, we can treat them as a particle of the whole system of the wheel and children, so we take the distance of the children from the center of the wheel, so I_kids=25*4*1.5^2, I_kids = 225kgm^2, and since there is no external torque, angular momentum is conserved, so we use L_initial = L_final, so L_initial = I_wheel*omega_wheel, and L_final = (I_kids+I_wheel)*omega_final, so L_final = (225+120)*omega_final = 120*0.5 = 60kgm^2rad/s, so 345omega_final = 60, omega_final = 60/345 = 0.17 rad/s, and so now we can use the conservation of rotational energy, W_net = W_conservative + W_nonconservative = KE_final - KE_initial = 0 + W_nonconservative, so 345*(0.17)^2/2 - 120*(.5)^2/2 = W_nc = 5 - 15 = -10 kgm^2rev/s, so 10 kgm^2rev/s of energy is lost, if we convert it to radians we get -10kgm^2rev/s*2Pirad/1rev = -20_Pi_kgm^2rad/s
0.5 rev/s (Hz) is the frequency, not the angular velocity. [tex]\omega=2\pi f[/tex].
otherwise everything else is correct?
