Angular velocity for a turntable
The discussion focuses on calculating the angular velocity of a turntable after one complete revolution, given its constant angular acceleration. Participants emphasize the need to use angular quantities instead of linear ones when applying kinematic equations. The correct approach involves substituting linear variables with their angular counterparts, such as using angular displacement and angular acceleration. Resources like HyperPhysics are suggested for further clarification on the topic. Understanding the relationship between linear and angular motion is crucial for solving the problem accurately.
captainsmith1
A turntable that is initially at rest is set in motion with constant angular acceleration a. What is the angular velocity of the turntable after it has made one complete revolution?
2(pi)rads=1 revolution
the 3 constant acceleration equations, i think the one you use is v2=vi2+2ad, d being distance traveled
im not sure what to substitue the variables for, and I am not even sure if I am using the correct acceleration equation.
captainsmith1 said:
… i think the one you use is v2=vi2+2ad …
Hi captainsmith1! :smile:
Yes, that's right, except you must use angles instead of distances.
From the PF Library on constant acceleration …
For an object moving in a circle, the same three equations may be used with angular acceleration velocity and displacement instead of ordinary (linear) acceleration velocity and displacement.​
EDIT: Doc Al beat me to it! :biggrin:
