Angular velocity of an oxygen molecule.
The discussion revolves around calculating the angular velocity of an oxygen molecule, considering its rotational and translational kinetic energies. The problem involves concepts from molecular physics and rotational dynamics.
  • Mixed
  • The original poster attempts to calculate angular velocity using given molecular speed and distances, while expressing uncertainty about their method for determining moment of inertia.
  • Some participants suggest that the mass of the oxygen atoms may not need to be computed, proposing a symbolic approach instead.
  • Others raise questions about the correctness of the relationship between rotational and translational kinetic energies.
  • One participant provides an alternative calculation method, leading to a similar angular velocity result.
  • Another participant points out potential errors in the original poster's calculations, specifically regarding the squaring of speed and the mass used for the moment of inertia.
The discussion is active, with participants providing hints and questioning assumptions. Some guidance has been offered regarding the approach to calculating angular velocity, and there are multiple interpretations being explored without a clear consensus on the correct method.
Participants note the importance of precision in calculations, particularly in relation to significant figures based on the provided data. There is also mention of the age of the thread, which may influence the nature of responses.
j_namtirach
The atoms in the oxygen molecule [O][/2] may be considered to be point masses separated by a distance of 1.2 x 10^-10 m. The molecular speed of an oxygen molecule at s.t.p. is 460 m/s. Given that the rotational kinetic energy of the molecule is two-thirds the of its translational kinetic energy, calculate its angular velocity at s.t.p. assuming that molecular rotation takes place about an axis through the centre of, and perpendicular to, the line joining the atoms.
K.E. = 1/2 mv^2
K.E. = 1/2 Iω^2
I = ∑mr^2
n = N/Na
m = nμ
no. moles of oxygen = 1/6.02 x 10^23 = 1.66 x 10^-24 mol
mass of oxygen molecule = (1.66 x 10^-24) x 32 = 5.32 x 10^-23 g = 5.32 x 10^-26 kg
translational K.E. of oxygen molecule = 0.5 x (5.32 x 10^-26) x 460 = 1.22 x 10^-23 J
rotational K.E. of oxygen molecule = 2/3 x 1.22 x 10^-23 J = 8.15 x 10^-24 J
I = 2(mr^2) = 2((5.32 x 10^-32) x (6 x 10^-11)^2) = 3.83 x 10^-46 kg m^2
angular velocity of oxygen molecule, ω = sqrt(((8.15 x 10^-24) x 2)/3.83 x 10^-46) = 2.06 x 10^11 rad/s
I think the correct answer is 6.3 x 10^12 rad/s. I'm not sure where I have gone wrong here. I'm not sure if I used the correct method for working out the moment of inertia. Any guidance would be much appreciated.
Thanks.
You do not have to compute the mass of the oxygen atoms to obtain your answer. You can treat the two oxygen atoms as point masses rotating about an axis through the centre of rotation. So, if you carry the calculation through symbolically, the mass term should cancel.
Should you not have ##E_{\text{rot}} = \frac{2}{3} E_{\text{trans}}##?
OK, I've got it now, thanks!
I don't know if this is the way...but I kind of got the close answer....
we have d = 1.2 × 10^-10
r = d/2 = 0.6 × 10 ^-10
v = 460
3 × rotational KE = 2 × translational KE
(3 . I . w^2 ) / 2 = (2 . m . v^2) / 2
3 . m . r^2 . w^2 = 2 . m . v^2
w^2 = (2/3) . v^2/r^2
w = ✓(2/3) . v/r
w = ✓(2/3) . 460/0.6×10^-10
w = ✓(2/3) . (7.67 × 10^12)
w = 6.26 × 10^12 rad/s
Welcome to PF. :smile:
We usually don't allow full solutions to be posted in Homework threads (except by the Original Poster, of course), but since this question thread is 8 years old, it is okay in this case.
In active schoolwork threads, please provide hints, ask probing questions, find mistakes, etc. But please do not post solutions in active schoolwork threads -- we require that the student do the bulk of the work. Thanks. :smile:
v = 460
w = ✓(2/3) . v/r
Your only mistake is in regards to precision. The diameter is only given to two sig figs, so your answer should not have more. Rounding your 6.26 to 6.3 completes it.
There are two errors in the OP:
You have forgotten to square the speed.
You need to use the mass of an oxygen atom, not an oxygen molecule. (Or else, like @Prabin Acharya, use the molecular mass and the formula I = mr2.)
Which is eight years old.
10K
