Another Newton law theoroy question
When pushing an armchair across a carpet at a constant speed of v, a force of 100N is applied. If the chair is pushed at a constant speed of 2v, the required force must be evaluated in relation to resistive forces, likely due to friction. The discussion highlights that while the net force is zero at constant speed, there must be a force counteracting the applied 100N. The resistive force's response to increased velocity is questioned, indicating a need for understanding friction dynamics. Overall, the problem is deemed solvable with the provided information, despite initial concerns about its completeness.
narutodemonki
pushing an armchair across a carpeted or at constant speed v you apply a force of 100N
if you push same chair at constant speed 2v(twice as fast) you mush push with a force?
a)100N
B)141N
Newtons second law? if the net force acting on object is zero or if no force is acting on object..objects at rest will stay at rest and objects in uniform motion will stay in uniform motion in a constant velocity straight lien unless acted on by a non negative resultant force.
...since the speed is constant that means no force is being applied? but the initial force was 100N? and was 100N for a while until the 2v speed was reached?
If the velocity is constant, that means that no net force is being applied. Which means that something is counteracting the 100N being applied, what force is that?
If you double the velocity, how will that resistive force respond? (look at how the equation for that particular resistive force varies with velocity)
It sounds like a friction problem, however I'm not sure you have given enough of the details to solve.
Well the question is straight from the practice section of the text. That is all the info they have given.
Yes, for this type of problem (simplicity-wise), its enough information.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
  • · Replies 41 ·
