Another Turning point question
  • Thread starter Thread starter lionely
    Point Turning
15 replies · 3K views
lionely
Find the equation of the tangent to the curve xy=4 at the point P whose coordinates are (2t,2/t). If O is the origin and the tangent at P meets the x-axis at A and the y-axis at B, prove
(a) that P is the midpoint of AB
(b) that the area of Triangle OAB is the same for all positions of P.
Find the the equations of the normals to the curve xy=4 which are parallel to the line
4x-y-2=0.
I got the equation of the of the tangent at P to be yt2 - 4t -x = 0
Not sure how to do a and b I don't really have much information about AB other than it's points like on P basically.
The y-coordinate of A is 0. It lies on the tangent, so it satisfies yt2 - 4t -x = 0. What is its x-coordinate?
4x-y-2=0.
Now that you have the coordinates for point A, find the coordinates for point B. (The x coordinate for point B is 0.)
B is (0, 4/t) oh and when you work it out the mid point is in fact P... to do part b now do I find the length of the lines and work out the area?
Draw a sketch .
The result should be pretty obvious.
So no calculations are needed to prove it?
How would I do the final part if I don't know any points for the normals?
I just noticed that must be an error in your equation for the tangent line. Assuming that t is positive, both intercepts should be positive.
You have the wrong sign on x.
This should be okay now right?
Area = 1/2 * 4t * 4/t = 8
Hence constant.
yt2 - 4t + x = 0
Yeah now I see it, thanks. But the final part of the question
4x-y-2=0.
How would I do this without having any points for the normals?
I get the normal as y=4x-15
How did you calculate it I don't understand we don't have any points.
:S
:S
I'm not sure I am right.
But, Slope * Slope_normal = -1
You know Slope of curve so find slope of normal.
Then equate it to slope of given line to find where the normal lies.
slope of curve = -4x^2 = equation of given line 4x-2
solve for x? then get y from equation of the curve then find equation of normal?
IGNORE this makes no sense.
