Another Water Riddle: What Will Happen & Why?
  • Thread starter Thread starter micromass
    Riddle Water
The discussion revolves around a riddle involving a system of bottles and tubes, exploring what will happen when water is introduced into the system. Participants analyze the mechanics of fluid dynamics, air pressure, and the potential outcomes based on the configuration of the bottles and tubes.
  • Some participants suggest that introducing water into the system will lead to water flowing from bottle "b" into bottle "c" through tube "d", but the exact mechanics are debated.
  • One participant questions the assumptions about the placement of the tubes, arguing that they appear to be outside the bottles, which could affect the outcome.
  • Another participant proposes that air pressure in bottle "c" will build up and facilitate water movement, but acknowledges that the complete solution is not yet clear.
  • Some argue that the water levels in the tubes will reach equilibrium, while others suggest that the configuration of the tubes will prevent this from happening.
  • A participant compares the system to a manometer, indicating that the water level in the yellow tube must match that in bottle "a", but notes that initial air pressure will influence the outcome.
  • There is mention of potential complications, such as the effect of back pressure from bottle "c" once it fills, which could halt further water movement.
  • Another participant introduces the idea of adding more bottles to the system, suggesting that this could alter the dynamics significantly.
Participants do not reach a consensus; multiple competing views remain regarding the behavior of the water in the system and the influence of air pressure. The discussion is characterized by uncertainty and varying interpretations of the mechanics involved.
Participants express uncertainty about the initial conditions, such as the air pressure in the bottles and the configuration of the tubes, which may significantly affect the outcomes discussed.
micromass
Staff Emeritus
Homework Helper
Insights Author
What will happen? And why?
micromass will get banned because discussion of perpetual motion machines is prohibited at PF?
That looks an awful lot like a drawing for one of those perpetual motion thingys. :nb)
It does, but what would actually happen?
If you insist. :smile:
I'm assuming that bottle a is open at the top. Water from bottle a will move into bottle c, causing the air pressure to increase in bottle c and b. This will cause the water level in tube d to rise until it equals the level of the water in bottle a.
If a is not open, then nothing will change.
It would actually topple over?
What are we doing to the bottles?
If we squirt water down the yellow hose, water will come back up into bottle "a".
If you want to get technical about it: from my perspective the diagram is drawn showing the tubes outside of the bottles and are either glued to the outside of the bottle or floating without support in the front- they could have easily been drawn to appear inside the bottles, so as to indicate holes are present to connect the bottles You have to assume there are holes, but if the tubes were represented to be inside the bottles, then we still wouldn't know if tube d, e, & f are actually in two pieces or not.
There is more evidence that the tubes exist outside of the bottles than inside the bottles. Can someone point out to me why I should assume that the tubes exist inside of the bottles? All of the bottles appear closed to me, whether or not the bottles are stacked or glued, I still think it would topple over. That or some cat will come along and knock it over, the water will slowly evaporate, bottle b will burst during freezing, or the bottle will degrade over time.
But I don't see anything representing the addition of more water. o_O
An interesting puzzle. Without doing a very detailed analysis, I think the air pressure in bottle c will build up from water dripping down through the straw from bottle a. Bottle b will have this same pressure which will easily be sufficient to cause water to flow up the 11" of tube "d" and thereby work its way down to bottle c. Bottle b will be nearly emptied, until it no longer has a connection to tube d and all the water will wind up in bottle c. Near the end though, water will flow up the 9" tube e into bottle b and into the bottom of bottle b and up tube d. I don't quite have a complete solution yet. Thank you @micromass . I will need to give it a little additional effort. The finish could be a little tricky.
all the water in bottles a and b will end up in bottle c.
It would be nice to have an answer for this (if there is one) or at least have micromass post his solution for it. The other water riddle wasn't resolved either. :H
I think that counter-intuitively the approximately 15" height of water pressure in tube (f) will be transferred to the air at the top of bottle (b) and that will be enough to lift water up tube (d) back into the top, as suggested by @Charles Link, causing (a) to remain at an approximately constant level. The overall initial effect is then to transfer water from (b) through (a) to (c).
I think this will end soon after (c) becomes sufficiently full that the water level in (c) passes the bottom tube (e), as after that point the back pressure due to the water in tube (e) will prevent the pressure in (b) from being sufficient to lift any more water up tube (d). It will then end with (a) containing a similar amount to when it started, (b) containing a similar small amount and (c) being full up to the bottom of (e). However, that all depends on the exact relative capacities which are not clearly indicated.
This may be naive, but (assuming A is open at the top) isn't it essentially a manometer with a couple of air bubbles? So the answer is that the water level in the yellow tube must reach the same height as the water in bottle A. The details would surely depend on the initial pressure of the air in B and C.
The blue tube connecting the air in bottle C to the air in bottle B makes it so that things will not reach the same level in bottle A. The blue tube could be 10 ft. long and the air pressure at the top of it (bottle B)would be essentially the same as the pressure at the bottom (bottle C). This makes an extension of the system. I believe the 11" length of tube d was chosen to be less than 15" so that water in bottle B would necessarily go through it and spill over from it even if the length of the blue tube was several feet long. (Another bottle could be put in the system (call it bottle D) (similar to bottle B) that the blue tube feeds into at a height several feet above this system. The water would go up an 11" tube from this bottle (because of the 15" length of tube "f") and spill right over. Clearly the water would not be at the same level as Bottle A.)
Assume the system is in equilibrium initially. Water added to a would go into c via the green, increasing air pressure in c. Displaced air would be transferred to b via the pink. This would exert pressure on the water in b, which would flow up and out through the yellow. What goes down must come up.
  • · Replies 16 ·
  • · Replies 27 ·
12K
  • · Replies 18 ·
