ANSYS Maxwell Impedance Matrix
2 replies · 6K views · last reply
jcesar1029
Hello everybody,
Three conductors are being simulated in Maxwell with a peak current. From Maxwell I extract the impedance matrix (3x3 matrix) of the three conductors. Conductors are placed on top of each other so there will be mutual inductances and resistances. The documentation on the impedance matrix (2 by 2 matrix) from ANSYS is shown here: http://imgur.com/dksxDVT
3x3 example is not available.
These conductors are being represented (Maxwell simulation) as 3 loops. Similar to what is shown in the documentation.
How do you calculate the total resistance and reactance or impedance of a single conductor from the matrix? I was told you add R11 + R12 + R13 (same idea for reactance add across) to get total resistance of a conductor but I believe that is wrong. Reason is because you have two different currents I1 and I2 in these terms.
  • The diagonal resistances are the self resistances due to DC component and skin effect as well as proximity effects. The off diagonal resistance is the result from proximity effect currents.
  • The diagonal inductance are the self inductance of each coil and the off diagonal inductance are the mutual inductance due to coupling.
Here http://imgur.com/88KNx8a I derived (2x2 matrix only meaning 2 conductors) where each equation comes from and how the impedance matrix is built.
Now I believe the components in Z11 represent the total resistance and reactance of one conductor. Then Z22 represents the total values for the second conductor, and so on for n condcutors.
I cannot find a source to back this up. Does anyone know if what I defined is true? or provide a documentation based on calculating total impedance of a single conductor with mutual resistances and inductance? I cannot find anything online.
Thank you, and let me know if there are any questions.
If you are unsure of how to interpret the results for three conductors. Remove one current/voltage source and simulate the system as a two circuit system, e.g. current in circuit 1 and 2. This will give you the case as in the documentation, with L11, L12, R11,R12, … ,R21. Then apply current to circuit 1 and 3, simulate and obtain the values, L13, L33 etc. Do the same with current applied to circuit 2 and 3. You will then have all the values you obtained from the simulation with 3 currents in your system. Compare the values and you may identify what is what and what not.
(the above assumes your FEM model is linear)
(also it is a good practice to compare to analytical calculation to verify the model ok)
good luck
