Why Are Polar Coordinates Essential in Solving the Ant and Rubber Band Problem?
The discussion centers on the necessity of using polar coordinates, specifically Lagrangian coordinates, to solve the Ant and Rubber Band problem. Participants emphasize that while Cartesian coordinates can be utilized, polar coordinates simplify the analysis of the ant's movement relative to the stretching rubber band. Key equations derived include the ant's speed in Lagrangian coordinates as ##\frac{L V}{L+ut}## and the time to reach a certain position as ##\frac{Lu(e^{\frac{u}{V}}-1)}##. The conversation highlights the importance of understanding the underlying concepts rather than solely relying on equations.
  • Understanding of Lagrangian coordinates
  • Familiarity with polar and Cartesian coordinate systems
  • Basic knowledge of calculus, particularly integration
  • Concept of relative motion in physics
  • Study the principles of Lagrangian mechanics
  • Learn how to apply polar coordinates in physics problems
  • Explore integration techniques for solving motion problems
  • Research the historical context of Galileo's methods in physics
Students of physics, mathematicians, and educators seeking to deepen their understanding of coordinate systems in motion analysis, particularly in complex problems like the Ant and Rubber Band scenario.
IamVector
An ant is moving along a rubber band at velocity
v = 1 cm/s. One end of the rubber band (the one from which
the ant started) is fixed to a wall, the other (initially at dis-
tance L = 1 m from the wall) is pulled at u = 1 m/s. Will the
ant reach the other end of the band? If yes then when will it
happen?
approach is : we can use the relative position on
the band which fraction k of the rubber is left behind starts with k = 0, and k = 1 corresponds to the ant reaching the end of the band .
why can't we use Cartesian coordinates and in which way to proceed?
Please show the Relevant Equations and show your work on this, or your thread will be deleted. Thank you.
Please show the Relevant Equations and show your work on this, or your thread will be deleted. Thank youl
ok
You can use whatever coordinates you like, but sometimes it is easier to use a frame of reference that is moving. Sometimes, even using a noninertial frame is easiest.
the hint given is related to using Lagrangian coordinates but I don't have any idea what they are.
http://glossary.ametsoc.org/wiki/Lagrangian_coordinates
Imagine that the band starts out marked in some equal intervals. Of course, the gap between them grows as the band is stretched, so in these units the ant slows down.
How fast is the ant going, in these units, at time t?
You don't have ANY idea what they are? Have you searched google or Wikipedia?
If you ask a specific question you may get an answer here, but this sounds like giving up.
"Solve my problem for me" isn't likely to work here.
You've gotten some good hints here, work with those and ask about what confuses you.
Hmm got the answer
Ant cover Vdt distance in dt time and final length of rubberband = L+ut
So dk = Vdt/(L+ut) on taking integrals and putting values t = e^100 - 1
[thread closed]
IamVector said:
Hmm got the answer
[thread closed]
Yes, that's good. To put it into a Lagrangian coordinates view you would say that speed of the ant in those coordinates is ##\frac{L V}{L+ut}##, etc.
Am I wrong to say you don't need any equations for this question?
Not sure how you are going to arrive at time =##\frac Lu(e^{\frac uV}-1)## without using equations.
I bet Galileo could do it. I think it involves an imaginary conversation where two rational people continually insult the village idiot while saying “therefore” a lot.
what does that even mean XD??
Galileo (and most philosophers for many hundreds of years before him) used the Socratic method. His observations were published in the form of dialogues between a wise teacher and two students: one a neutral inquisitive person and the other a devil’s advocate always making counter arguments for the teacher to shred. He was tellingly named ‘Simplicio’. In these dialogues instead of equations the relations are spelled out using language, so, for example you will find quotes like this,
“ The spaces described by a body falling from rest with a uniformly accelerated motion are to each other as the squares of the time intervals employed in traversing those distances.”
So I was jokingly saying Galileo would find a way to say it all with words and he would do so in the Socratic form.
of course I knew you were joking but what was the need? I thought something triggered you XD
You are right, I had hastily misread the questio.
Np
  • · Replies 16 ·
  • · Replies 35 ·
