Are There Better Antennas for Tx433/RX433 RF Modules?
  • Thread starter Thread starter digitalblggr
    Antennas
The discussion focuses on improving the performance of Tx433/Rx433 RF modules by utilizing better antenna designs. Users are currently limited to using simple wire antennas of 30-35 cm, which are insufficient for reliable data transmission over distances greater than a few centimeters. Recommendations include constructing a dipole antenna (34 cm) or a Yagi antenna (32.3 cm dipole with a 34.6 cm reflector and a 30.6 cm director) for enhanced signal reception. Additionally, using a half-wave voltage doubler with Schottky diodes like the BAT85 can help in testing and optimizing antenna performance.
  • Understanding of RF module operation, specifically Tx433/Rx433
  • Basic knowledge of antenna theory, including dipole and Yagi designs
  • Familiarity with electronic components such as Schottky diodes and capacitors
  • Ability to use multimeters for signal testing and measurement
  • Research how to design and build a Yagi antenna using online calculation tools
  • Learn about the principles of antenna impedance matching for optimal performance
  • Explore the use of voltage doublers in RF applications for signal testing
  • Investigate alternative antenna types and their suitability for 433 MHz RF communication
Electronics hobbyists, RF engineers, and anyone working with wireless communication systems seeking to enhance the performance of Tx433/Rx433 RF modules.
digitalblggr
HI,
I am using tx433/Rx433 RF modules to transfer some data between two AVRs. I know that we have to use 30-35 cm simple wires as antennas.
I send out out two bytes. The second byte is the actual data , and first byte is to get rid of unwanted information. However, I have a hard time receiving the signal, and have to send it out a bunch of times. I noticed if I play with wires(antennas) for e.g.when I get receiver antenna really close to transmitter I receive data much faster. This made me think maybe there is a better choice for antennas out there.
Any suggestions?
P.S. I am supplying 9V to Tx433..so I should at least get ~200feet according to the datasheet, but so far I can't go beyond few cms.
A quarter wave length at 433 MHz is 17.3 cm, so this is what you would use for a simple antenna. It should actually be a little shorter than this.
You can use a dipole which is a half wavelength (34 cm) fed in the middle by a short feedline.
Or, you could use a Yagi antenna which consists of a dipole (32.3 cm) fed as before with a reflector (34.6 cm) 5 cm behind it and a director (30.6 cm) 13 cm in front of it.
You can get calculation programs for designing Yagi antennas by searching on Google.
One of these is this one:
http://www.vk5dj.com/yagi.html
You can make a simple test antenna by connecting a half wave voltage doubler to the centre of a dipole and measuring the output of the voltage doubler using a multimeter on a low current range.
The voltage doubler should have Schottky diodes like the BAT85 in it. The capacitors should be about 1000 pF but cut to have very short leads.
In this diagram, above, you would omit the transformer and connect the two ends of the dipole feedpoint to the input of the doubler.
With this tester, you could adjust the transmit antenna for maximum received signal into the tester. You do this by adjusting the spacing between the elements of the Yagi.
Then you could make a similar one for the receiver and test it by attaching it to the transmitter.
Using better antennas should give you more reliable results and teach you a lot about antennas.
  • · Replies 19 ·
9K
16K
  • · Replies 20 ·
