Any ideas for an explicit formula?
  • Context: Graduate
  • Thread starter Thread starter Someone2841
    Explicit Formula Ideas
The discussion focuses on deriving an explicit formula for the sequence defined by the recurrence relations for \( a_{n,m} \), where \( n \geq m \). The initial conditions are \( a_{n,0} = 1 \) and \( a_{m,m} = m! \). The recursive relation is given by \( a_{n+1,m+1} = (m+1) \cdot a_{n,m} + a_{n,m+1} \). The contributors suggest clarifying the conditions for \( n \) and \( m \) and propose a method to simplify the sum involved in the derivation of the explicit formula.
  • Understanding of recursive sequences and their properties
  • Familiarity with factorial notation and operations
  • Knowledge of combinatorial mathematics
  • Experience with mathematical summation techniques
  • Research combinatorial identities related to factorials
  • Explore methods for simplifying recursive relations in sequences
  • Learn about generating functions for sequences
  • Investigate explicit formulas for similar recursive sequences
Mathematicians, combinatorial theorists, and students studying advanced sequences and series who are interested in deriving explicit formulas from recursive definitions.
Someone2841
Let an,m be defined for the non-negative integers n and m such that n ≥ m.
an,0 = 1
am,m = m!
an+1,m+1 = (m+1) * an,m + an,m+1
Is there an explicit formula f such that f(n,m) = an,m?
Here are the first numbers of the sequence:
<br /> <br /> \begin{align}<br /> &amp;m&amp;0&amp;1&amp;2&amp;3&amp;4\\<br /> n\\<br /> 0&amp;&amp;1\\<br /> 1&amp;&amp;1&amp;1\\<br /> 2&amp;&amp;1&amp;3&amp;2\\<br /> 3&amp;&amp;1&amp;6&amp;11&amp;6\\<br /> 4&amp;&amp;1&amp;10&amp;35&amp;50&amp;24\\<br /> 5&amp;&amp;1&amp;5&amp;85&amp;225&amp;274&amp;12\\<br /> \end{align}<br /> <br />
Hi!
So first of all I wouldn't recommend choosing the title you chose it doesn't say anything about the problem so people that actually know the answer might just skip it.
Also it seems that your third formula gives me an expression for a_{n,m} with n smaller then m if you fill in a_{m+1,m+1}. So either you need to state explicitely that that formula only goes for n strictly greater than m or since the outcome is just that these a_{n,m} with n smaller than m are 0 just define them to be 0. This also takes away the need for the second identity since in the case you put these to 0 it is implied by the third!
So doing it this way I just start with the first identity and fill in the recursive relation again. which yields (so here n\geq m\geq 1)
a_{n,m}=ma_{n-1,m-1}+a_{n-1,m}=m(m-1)a_{n-2,m-2} +a_{n-1,m} +ma_{n-2,m-1}=\ldots=m!a_{n-m,0}+\displaystyle\sum_{i=1}^m \frac{m!}{(m+1-i)!}a_{n-i,m+1-i}\\=m!(1+\displaystyle\sum_{i=1}^m \frac{a_{n-i,m+1-i}}{(m+1-i)!}).
So now we just have to figure out that sum. Which I think is quite doable, I did it a little bit, but it will probably cost some time to do it this way. SO maybe someone else has a shorter way. If not this will definitely work if you just keep putting the recurrence relation in until you know that you are just adding zeros or ones and then you are done. For instance as a next step the sum will split into another sum and a shorter sum. Doing this will give you a double sum with all indices reduced and something lke (n-m+1) or something like that. Then you keep on making every sum shorter and getting shorter double sums or tripple sums or whatever and eventually you will just get some kind of m tuple sum that only has 1 term anyway and then you are done. This may not be the most elegant way to solve the problem, but at least it works.
  • · Replies 26 ·
  • · Replies 21 ·
  • · Replies 18 ·
