Anyone has done the 1-loop cancellation for the Wess-Zumino model?
  • Context: Graduate
  • Thread starter Thread starter diegoRED
    Model
The discussion revolves around the calculation of one-loop vacuum energy in the Wess-Zumino model, focusing on the cancellation of contributions and the challenges related to symmetry factors in the calculations. The scope includes theoretical aspects of supersymmetry and specific calculations within the model.
  • One participant expresses difficulty in achieving cancellation in the one-loop vacuum energy calculation for the Wess-Zumino model, suspecting an error in the symmetry factor for the boson diagram.
  • Another participant references major textbooks that cover the topic, suggesting that the calculation has been addressed in literature.
  • The first participant notes that the cited book avoids using the standard Lagrangian for the Wess-Zumino model, instead employing chiral superfields to circumvent combinatorial issues, which they believe is central to their problem.
  • A different participant suggests that understanding the cancellation of contributions to the Higgs mass might assist in checking the symmetry factors, referencing a specific lecture series that discusses the Wess-Zumino model.
Participants do not appear to reach consensus on the specific calculations or the correct approach to addressing the symmetry factors. Multiple viewpoints and methods are presented, indicating ongoing debate and uncertainty.
There are references to specific calculations and literature, but the discussion highlights unresolved issues regarding combinatorial factors and the application of different formulations of the Wess-Zumino model.
diegoRED
I am calculating the one loop vacuum energy in the Wess-Zumino model, and I don't get a cancellation. For sure I've messed up with the symmetry factor for the boson diagram, because in the fermion sector i have the cancellation (that is almost trivial). I an old post 2 guys were discussing of the 2-loop check, but would be nice for me to see the explicit cancellation for the original lagrangian of wess-zumino at 1-loop.
I say in advance that I know that in superfields formalism the problem of susy UV cancellations is almost straightforward and that it's possible to go easily to higher loop calculations for simple models like the Wess-Zumino, but I would like to get rid of this problem, because it makes me think that I can not calculate the symmetry factor!
The original lagrangian of wess-zumino in component is in the euclidean:
L= 1/2g^2(A^2+B^2)^2+Mg(A^3+AB^2)+A\bar{\psi}\psi+igB\bar{psi}\gamma_{5}\psi
thanks for your attention
I saw your earlier post in a thread between nrqed and me years ago. I didn't reply b/c I don't have my notes handy. But this is done in several major textbooks. For example, check out "Supersymmetric gauge field theory and string theory," by David Bailin, Alexander Love.
thank you very much.
However I want to stress that in the book that you have cited, the authors carefully avoid to use the standard lagrangian for the wess-zumino model. They introduce 3 different chiral superfiled and this trick eliminates the problem of the combinatorial factors (that was clearly my problem)... If you have done the computation in detail for wess-zumino with the right combinatorial factors I would really like to see were I get wrong my calculations.
I,m not sure to understand your problem. But probably the calculation of cancellation of contributions to Higgs mass helps you to check the symmetry factors. This calculation is done precisely for the Wess-Zumino model in :
"Cambridge Lectures on Supersymmetry and Extra Dimensions"
Lectures by: Fernando Quevedo pages 48 , 49
Now I have checked it in the homepage of Dr.Quevedo and seen that in that version this calculation is not present. So if you think it might be useful to look at it
I can send it to your mail.( I could not copy from pdf to paste on this page )
  • · Replies 27 ·
  • · Replies 0 ·
  • · Replies 0 ·
